Camber kit for 02 DC5??
I just droped my car and you know.. the common thing happens when u drop your car, and your back wheels get a bad camber angle to them. Yeh anyway I just wanted to know if all i need is a rear camber kit, to fix the angle and to fix my steering allignment, or do I need both front and rear?? Feed back is welcome.
You'll most likely need the rear. Depending on how low you go you may need the front ones as well. I only put the camber kits in the rear as my fronts are off by less than 1 degree no unusual camber wear
