how many hp?...and after tune?
so i have a 98 gsr obd2, so far these are my mods
block
pct pistons (standard)
2 oem headgaskets (couldnt take much more of the high compression)
compression at 11.9 i suppose?
head
blox IM
ecu
stock
stiff stuff
fuel pressure regulator 48psi
megan 4-1 header 2.5 collector
with test pipe
apex dunk 2.25 cat-back
es oval
F&S stage 2 6 puck dual springed
itr flywheel
ok so my question is, what hp am i going to expect? and after tuned?
have any of you been dissapointed with their dyno sheets?
is there something in my list i should change/replace with something that will give me better number?....
block
head
blox IM
ecu
stock
stiff stuff
with test pipe
es oval
itr flywheel
.john.
Honda S2000
Jan 27, 2007 10:52 AM
1999all_motoR_teg
10
Dec 5, 2004 07:28 AM
