how do i take off the front bumper?
is it hard?? cause i'm putting on a cold air intake and i just need some help on how to take off the front bumper and if anyone has pics of how to that would be awsome. thanks
No need to man turn ur wheel all the way to the left go to the right tire take the splash gard off go under the front of the bumper take that plastic off or just leave it hangin then when ur stock air box is off ull see the little air bucket thats already in ther thers two bolts or screws i belive take those off from the bottom and rip it down then just stick the tube threw the hole and hook the filter up from the bottom its easy
sweet thanks for the help man but i know i should have said this earlier but i'm also going to try and put a JDM front bumper on (when i get the money)
super easy:
1. Open hood
2. take out the two front amber bumper lights with a phillips screwdriver. Gently pry the light assembly out with a small flathead screwdriver.
3. Take your phillips screwdriver and then remove the two phillips screws on each side of the wheel well where the bumper black trim meets the fender. Take both screws out on BOTH sides of the car.
4. Take a 14 MM socket with a long extension and then remove two 14mm bolts that are tucked in the hole where you just removed the amber turn signal lights. Each side has 2 bolts.
5. Lift the bumper UP and away from the car's frame.
Total time: Less than 10 minutes
1. Open hood
I can't remember if you had to remove the corner lamps too. If you do then do the following:
on the 88 CRX's those corner lights also use two phillips screws on each side.
Sweet thanks for the detailed help stevescivic, i'll take it off tomorrow when theres day light just so i know what i'm doing when i get the JDM bumper
make sure research all the fine details that are needed to install a jdm bumper as there are known issues/fixes to do the conversion.
If my memory serves me right you need to change/remove/modify the rad suport to accomodate the new bumper.
just look around H-T you'll find someone here with a detailed write up
AdRoz
Dec 27, 2007 05:50 PM
rasta420
Jul 3, 2002 08:50 PM
89 CRX SI
May 23, 2002 07:40 PM
