Installing an Engine Dampener
Old Sep 7, 2006 | 07:16 PM
smoothe's Avatar
Default Installing an Engine Dampener
I just picked up the Spoon engine dampener and the instructions are in Japanese. the picture they provide is sketchy at best. It doesn't show the mounting points on the engine and the body.
Has anybody installed an engine dampener before? If so, can you please assist.
Thanks.
And yes, I have searched.
Old Sep 7, 2006 | 07:37 PM
DC2fanboy's Avatar
Default Re: Installing an Engine Dampener (smoothe)
if it's the type I think it is, you will probably have a problem getting it to install on a LHD ITR
Might need to rig something up to get it to work...
Old Sep 7, 2006 | 07:40 PM
Reid's Avatar
Global Moderator
If you really care about controlling the movement of the engine, get stiffer engine mounts.
Those engine torque dampeners are a gimmick IMHO.
Old Sep 7, 2006 | 07:54 PM
RagingAngel's Avatar
Default Re: Installing an Engine Dampener (Reid)
They do work Reid....
well at least when I observe it on a dyno with and without....
but I also managed to bust a J's Racing one (not mine, which was ) as it desperately tried to control wheel hop during a test and tune drag session....
So it must be doing something of sorts.... besides, Spoon hasn't released any new products for the EG/DC line in a while.... just don't use this mount/damper for drag imo....
Old Sep 7, 2006 | 08:22 PM
smoothe's Avatar
Default Re: Installing an Engine Dampener (RagingAngel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RagingAngel &raquo;</TD></TR><TR><TD CLASS="quote">They do work Reid....
So it must be doing something of sorts.... besides, Spoon hasn't released any new products for the EG/DC line in a while.... just don't use this mount/damper for drag imo.... </TD></TR></TABLE>
Was yours installed on an integra or EG? I just looked at the brackets that were provided and they need to be modified to clear the brake fluid resevoir. Do you have pics of yours installed?
Old Sep 7, 2006 | 09:43 PM
Reid's Avatar
Global Moderator
well at least when I observe it on a dyno with and without....</TD></TR></TABLE>
Oh, don't get me wrong, I've seen them work. It's just that if you want to control engine movement, it seems to make more sense to get to the root of the problem (the engine mounts).
Old Sep 7, 2006 | 09:52 PM
dc2vu's Avatar
just install it right that engine damper will clear the brake resevoir, i have the same style and so does my buddy in his integra...the only other affordable option for engine movement is either filled in torque mounts or es inserts...both of which cause more vibration than im willing to put up with.
Old Sep 8, 2006 | 06:57 AM
R you serious's Avatar
reid you should know..
i think maybe those engine dampners are so popular over seas is because from what ive gathered many of the top honda tuner companies in japan strive so hard for the balance.
Stiff *** mounts are going to give more load to axles and other compnents, thus ruining the zen
Old Sep 8, 2006 | 07:05 AM
Reid's Avatar
Global Moderator
Default Re: Installing an Engine Dampener (R you serious)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R you serious &raquo;</TD></TR><TR><TD CLASS="quote">reid you should know..
Stiff *** mounts are going to give more load to axles and other compnents, thus ruining the zen </TD></TR></TABLE>
Actually, what I've noticed is that a company can make one engine dampener and brackets to make the dampener fit in lots of cars. It's easy for them to package and market to a wide variety of vehicles, with relatively little R&D.
Old Sep 8, 2006 | 08:00 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smoothe &raquo;</TD></TR><TR><TD CLASS="quote">Was yours installed on an integra or EG? I just looked at the brackets that were provided and they need to be modified to clear the brake fluid resevoir. Do you have pics of yours installed?</TD></TR></TABLE>
Neither - it was put on a 6th gen hatch.
Even the Spoon engine mounts didn't help in saving it from being bent the way it got. We elected to remove it altogether as it was dangerously close to the exposed camgears.
Old Sep 8, 2006 | 08:24 AM
does it fit with the cam gears covered?
Old Sep 8, 2006 | 08:34 AM
fits no problem with camgears covered....
The alignment should be almost parallel with the side of the valvecover... I just busted it by bending it with violent launches
Old Sep 8, 2006 | 08:41 AM
mugenracer's Avatar
I'm guessing the reason it bent was because its not fitted correctly, theyre designed to be fitted at the rear of the engine. Fitting it in that location possibly caused a twisting force on it when the engine rocked back/forth, when theyre fitted at the rear the engine applies lateral force on it. Mine has been on my car since i bought the car almost 3 years ago and its taken quite a few hard dumps/starts and its been fine, and i believe it is the reason my engine mounts are still in very good condition.
Old Sep 8, 2006 | 08:54 AM
Default Re: Installing an Engine Dampener (mugenracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugenracer &raquo;</TD></TR><TR><TD CLASS="quote">I'm guessing the reason it bent was because its not fitted correctly, theyre designed to be fitted at the rear of the engine.
Well I'm pretty sure it is fitted and installed properly. It's just likely that it wasn't designed properly....so nuts on J's Racing or whoever it really was who thought this would be the ideal location for the 6th gen hatch
Old Sep 8, 2006 | 11:34 AM
smoothe's Avatar
Default Re: (dc2vu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2vu &raquo;</TD></TR><TR><TD CLASS="quote">just install it right that engine damper will clear the brake resevoir, i have the same style and so does my buddy in his integra...the only other affordable option for engine movement is either filled in torque mounts or es inserts...both of which cause more vibration than im willing to put up with.</TD></TR></TABLE>
It wont clear the brake fluid resevoir. The brackets are exactly the same as these
Do you have any pics of yours or your buddies???
Old Sep 8, 2006 | 11:36 AM
Weel's Avatar
Well I'm pretty sure it is fitted and installed properly. It's just likely that it wasn't designed properly....so nuts on J's Racing or whoever it really was who thought this would be the ideal location for the 6th gen hatch </TD></TR></TABLE>
yup thats installed right, I used to have one on my 1998 JDM Civic Type-R and it worked wonders. Really good and inexpensive mod imo
Old Sep 8, 2006 | 01:41 PM
SilverDc2's Avatar
Default Re: Installing an Engine Dampener (NZMugenITR)
i used to have one in my integra, it seemed to work, i think their all the same j's, spoon, nrg, etc..
Old Sep 8, 2006 | 01:49 PM
92TypeR's Avatar
FSAE
Default Re: Installing an Engine Dampener (SilverDc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilverDc2 &raquo;</TD></TR><TR><TD CLASS="quote">i used to have one in my integra, it seemed to work, i think their all the same j's, spoon, nrg, etc..</TD></TR></TABLE>
You are correct.
Silk Road has the standing patent on engine torque dampeners, and they in fact are the sole manufacturer of the dampeners as well.
Old Sep 8, 2006 | 01:58 PM
SilverDc2's Avatar
Default Re: Installing an Engine Dampener (92TypeR)
I bought a nrg one for 30-40 bucks and it was exactly the same than the j's racing except for the brackets and stickers. (shrugs)
Old Sep 8, 2006 | 03:10 PM
uNF$@#!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reid &raquo;</TD></TR><TR><TD CLASS="quote">
Actually, what I've noticed is that a company can make one engine dampener and brackets to make the dampener fit in lots of cars. It's easy for them to package and market to a wide variety of vehicles, with relatively little R&D.</TD></TR></TABLE>
what i cant figure out is, if they make one for the driver side of the motor, why not make one for the passenger side as well?
Old Sep 9, 2006 | 10:03 AM
DC231_01's Avatar
Default Re: Installing an Engine Dampener (uNF$@#!)
Why don't I just make us all some for a discounted price? I work @ a machine shop, it wouldn't be hard..
dc2vu's Avatar
Default Re: (smoothe)
I dont have any personal pics of my engine damper, but heres one i stole off of ebay
Old Sep 9, 2006 | 10:33 AM
ChicagoMike's Avatar
Default Re: (dc2vu)
Installed on a EM1. But at least the motors an R
Old Sep 9, 2006 | 11:10 AM
92TypeR's Avatar
FSAE
Default Re: Installing an Engine Dampener (DC231_01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC231_01 &raquo;</TD></TR><TR><TD CLASS="quote">Why don't I just make us all some for a discounted price? I work @ a machine shop, it wouldn't be hard.. </TD></TR></TABLE>
You would have to purchase the rights from Silk Road seeing as they hold the patent for engine torque dampeners.
Old Sep 9, 2006 | 11:25 AM
tommymoose's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by uNF$@#! &raquo;</TD></TR><TR><TD CLASS="quote">what i cant figure out is, if they make one for the driver side of the motor, why not make one for the passenger side as well?</TD></TR></TABLE>
because it would cost twice as much and do the same thing as doubling the damping stiffness of the single one.
