Repalced oxygen sensor no other code 1996 accord
I am getting a oxygen sensor replaced and this was the only code showing up. But I have a srs (air bag light) that stays on and also a abs light that will come in after moving a few feet or after starting up and idleing. The abs light will go off after starting up but will come back on. The air bag light stays on all the time. What can i check or any suggestion on what to do would be of great help. I have a 1996 accord v6 4 door with 131,000 miles on it.
Should it have codes for the other problems?
thanks
thanks
you could check to see if you have the Blue 2 pin connector above the passenger side kick panel, if it is jumpered and the key turned on you can get the 'flash' codes
dooing some checking and when I start enginie the abs light comes on and then goes off but it come back on in a few seconds. There is a loud click when it come back at the abs fuse box, Do you think a relay could be bad for the click to be so loaud coming from there???
supermotothud
Jun 11, 2008 06:14 PM
mstewar
Jan 22, 2007 09:04 AM
