Headlights shutting off randomly while driving...(searched no help)
Old Sep 7, 2006 | 05:52 PM
granturismonut2's Avatar
Default Headlights shutting off randomly while driving...(searched no help)
I have a 1993 Civic DX 4 door, and I am having a problem with the headlights shutting off at random while driving, mainly on low beam, I have checked the fuses, installed new bulbs and still it presists. Anyone have any ideas? relays? (location) Thanks in advance
Old Sep 7, 2006 | 05:53 PM
Ej1_coupe's Avatar
Default Re: Headlights shutting off randomly while driving...(searched no help) (granturismonut2)
check all your connections, sounds like you have a loose one.
Old Sep 8, 2006 | 07:28 PM
Default Re: Headlights shutting off randomly while driving...(searched no help) (Ej1_coupe)
I checked all I could find. was just wondering maybe someone else had this problem and knew where to point me in the right direction. is there a relay I can check or maybe in the turn signal stalk? just wondering. TIA
Old Sep 8, 2006 | 07:33 PM
wheelmanbg's Avatar
sounds like a bad ground.
or maybe your bulbs are not in firmly. check the clips that hold them in
wait, BOTH headlights are shutting off or just one at a time?
Old Sep 8, 2006 | 07:37 PM
Eran's Avatar
HT White Ops
A while back, when PW:JDM first started selling their "uber hella jdm yellow" bulbs, they had some problems. Their prongs were kind of fucked, and didn't fit right into the H4 plug. Mine always got really dim or they shut off. Look into what kind of bulbs you're buying.
Old Sep 9, 2006 | 12:28 AM
no_money2supe's Avatar
Do you have aftermarket bulbs installed? I had that before and because of the larger voltage draw, the connectors behind somewhat melted and I had this exact problem for my car. I simply pulled the connectors off some junk cars and spliced them in place of my melted ones. And voila, the problem was solved!
Old Sep 9, 2006 | 12:31 AM
SLO Sol's Avatar
get some 30 dollar foglights installed so you atleast have some light when your lights go out
Old Sep 9, 2006 | 12:42 AM
Eran's Avatar
HT White Ops
Default Re: Headlights shutting off randomly while driving...(searched no help) (no_money2supe)
They also sell Nokya or something aftermarket H4 higher voltage harnesses at Schucks/Checker/Kragen and other places.
Old Sep 9, 2006 | 07:55 AM
Sketch_hs's Avatar
my guess would be the switch assembly... check it
Don'tKnoKnuthin
Sep 13, 2013 08:35 AM
Fuji_jaii
Feb 27, 2006 03:16 PM
95civic_b20turbo
Oct 23, 2005 08:49 AM
bncivic
Aug 8, 2005 05:44 PM
Commodore
May 13, 2003 07:16 AM
