Help with no pedal pressure *searched already*
Old Sep 7, 2006 | 03:40 PM
The One Upper's Avatar
Default Help with no pedal pressure *searched already*
I cant get any pedal pressure like i had before i started this brake job.
Replaced all 4 rotors and pads and bled them well.
Couldnt get barely pedal pressure so i changed the MC.
Very little difference in pressure with full bleeding of the system
What the hell could be wrong?
Old Sep 7, 2006 | 03:55 PM
dthug's Avatar
Default Re: Help with no pedal pressure *searched already* (The One Upper)
brake line prob busted and its leaking somewhere did you check all the lines
Old Sep 8, 2006 | 05:09 AM
just replaced all the lines with SS lines not too long ago but will check tonight......
i have some pedal pressure but its very slight
Old Sep 8, 2006 | 05:39 AM
-Gary-'s Avatar
Default Re: (The One Upper)
WHen yiou replaced the MC did you cycle the pedal till you removed all the bubbles from the fluid?
You have to do this *before* you connect it up to the brake lines.
Old Sep 8, 2006 | 05:50 AM
crvtec10's Avatar
H-T's Biggest Retard
Default Re: (-Gary-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -Gary- &raquo;</TD></TR><TR><TD CLASS="quote">WHen yiou replaced the MC did you cycle the pedal till you removed all the bubbles from the fluid?
You have to do this *before* you connect it up to the brake lines.</TD></TR></TABLE>
Minor thing but this s the truth!!!
Old Sep 8, 2006 | 06:35 AM
i didnt replace the MC i took it to the shop i trust. Im pretty sure they did this since the only person that works on my car is the owner.
Old Sep 8, 2006 | 06:37 AM
-Gary-'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The One Upper &raquo;</TD></TR><TR><TD CLASS="quote">i didnt replace the MC i took it to the shop i trust. Im pretty sure they did this since the only person that works on my car is the owner.</TD></TR></TABLE>
Have you called the shop and asked them?
Old Sep 8, 2006 | 07:59 AM
yea i told him yesterday it wasnt to my satisfaction. he said he checked everything and couldnt get it any better
Old Sep 8, 2006 | 08:01 AM
-Gary-'s Avatar
Sounds like it's time to take it somewhere else....
Old Sep 8, 2006 | 08:06 AM
schardbody's Avatar
what do you mean pedal pressure??? you mean theres no resistance in the pedal, it goes to the floor, or goes way lower than it should before you get any resistance.
GUESSING is retarded.
Old Sep 8, 2006 | 08:13 AM
Default Re: (schardbody)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schardbody &raquo;</TD></TR><TR><TD CLASS="quote">what do you mean pedal pressure??? you mean theres no resistance in the pedal, it goes to the floor, or goes way lower than it should before you get any resistance.
GUESSING is retarded.</TD></TR></TABLE>
i push the pedal about halfway to the floor before i get any pad contact to the rotor to slow the car down.
before i replaced the MC it would go completly to the floor before i got anything.
Old Sep 8, 2006 | 08:19 AM
-Gary-'s Avatar
It's air in the system.
Old Sep 8, 2006 | 08:33 AM
im going to rebleed them even though i dont think there is any air in the system.
Old Sep 8, 2006 | 08:44 AM
-Gary-'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The One Upper &raquo;</TD></TR><TR><TD CLASS="quote">im going to rebleed them even though i dont think there is any air in the system.</TD></TR></TABLE>
Good luck man.
I'm sorry you gotta go through that.
Old Sep 9, 2006 | 03:14 AM
schardbody's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The One Upper &raquo;</TD></TR><TR><TD CLASS="quote">i push the pedal about halfway to the floor before i get any pad contact to the rotor to slow the car down.
before i replaced the MC it would go completly to the floor before i got anything.</TD></TR></TABLE>
check all the slides on all 4 calipers, its either a stuck slide not letting the caliper(s) move easily, or a pad is cocked. recheck the brake job.
see if you can pump the pedal quickly and make the pedal feel better, also apply the parking brake and see if it makes a differance.
slowesteg
Suspension & Brakes
Sep 4, 2012 08:24 PM
Turbo-Honda
Suspension & Brakes
Jan 11, 2007 08:22 PM
CivicHP
Sep 30, 2005 01:32 PM
