SEARCHED..no luck on dizzy question.
i just started my ls/vtec build up and im starting to gather parts. My question is, what other obd-1 dizzys can i run besides the B series VTEC dizzy? Such as a sohc vtec one or just a non-vtec dizzy?
well since you are going to run a LS/Vtec engine setup, you will need to run a Vtec distributor. A non-vtec b-series distributor will work and have the engine running, but it will not perform properly as it should without the proper dizzy.
A SOHC d-series dizzy will not bolt up...nor work.
Get a b16a/b18c dizzy for your setup
markviiisvt4
Oct 17, 2007 08:08 AM
