how do i wire up a 94+ GSR cluster into my DA?
Old Sep 7, 2006 | 01:12 PM
ohsnapzafingcu's Avatar
I serve phở for my babies
Default how do i wire up a 94+ GSR cluster into my DA?
i know to wire everything but the speedo up...
i couldn't find anything that was done on this, but for some reason there's alot of write up for EFs?.. is it the same wiring for the speedo pretty much?
Old Sep 7, 2006 | 01:40 PM
turbob16ef's Avatar
From: if you build it they will come, the bottom carolina, duh
Default Re: how do i wire up a 94+ GSR cluster into my DA? (ohsnapzafingcu)
yeah it is the same as an EF. just get an electronic vss and the cable.
Rob
Old Sep 7, 2006 | 01:47 PM
Default Re: how do i wire up a 94+ GSR cluster into my DA? (turbob16EF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbob16EF &raquo;</TD></TR><TR><TD CLASS="quote">yeah it is the same as an EF. just get an electronic vss and the cable.
Rob</TD></TR></TABLE>
thanks bud, are their any write ups?.. if not i'll probably try to make one
Old Sep 7, 2006 | 02:14 PM
dang i lied about wiring it up. it's alot harder then i thought. does anyone have a wire diagram?
or the writeup for the EF? can't seem to find it now
Old Sep 7, 2006 | 03:40 PM
turbob16ef's Avatar
try going onto g2 and searching.
Old Sep 7, 2006 | 03:55 PM
turbob16ef's Avatar
if you are registered for g2 just go on there and type in gsr cluster swap, there was a guy on there who did a ITR cluster swap and i thnk did a write up on it, but he goes through all of the colors of the wire on each.
Old Sep 7, 2006 | 05:38 PM
sweet good thinkin nd thanks
Old Sep 16, 2006 | 01:51 PM
PLAN:B's Avatar
I just finished a '97 JDM Type R into a DA9. It is Miguel's car from MOB Works Paint & Autobody.
If you need some info, or have questions, e-mail me: mikem@planbmotorsports.com or call the shop @ 949.600.6161
Goodluck man
EFboostedSI
10
Jan 19, 2011 09:10 AM
InTheLBC20
22
Aug 6, 2010 01:59 AM
civickid03
Jul 20, 2006 06:03 PM
CRX_VTEC
Aug 17, 2003 07:36 PM
