Where exactly is the main relay for a 91 teg?
I want to change my main relay but i cant seem to locate it. Well I see alot of relay under the dash but they all look alike which is it?
A pic would be helpful Thanxs.
It looks like this
<Hope they don't mind I'm using their pic>
It's bolted on close to the steering wheel with a 10mm bolt. Has a short metal hanger attached to it for the bolt. If I remember its hanger and bolt is usually paired up with another smaller relay and hanger. If you remove your lower dash/kick panel (the one below the steering), you can clearly see the main fuel relay, and the 10mm bolt. It faces right towards you, towards the left of the steering column.
-- Kevin
-- Kevin
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jose-aka-Pedro »</TD></TR><TR><TD CLASS="quote">Unless I'm wrong that is the MFR, Main fuel relay.
It should click when you turn the key to the on position.
Same thing diffrent name
lrcrx90
Nov 27, 2006 02:06 PM
rody084
Jul 14, 2003 11:53 PM
