trying to remove ecu.... help
Old Sep 7, 2006 | 11:51 AM
DelSolMarine's Avatar
Default trying to remove ecu.... help
ok im having trouble pulling the plugs outta my ecu... the 3 plugs its a del sol si with a b18c ecu and the plugs wont come out and when one of my friends tried a blue wire came loose from one of the plugs... solid blue and i see u push the middle thing in but they wont come out... is there some trick to this?
Old Sep 7, 2006 | 12:27 PM
Default Re: trying to remove ecu.... help (DelSolMarine)
ok so i got out the plugs and i finished what i was doin and plugged them into my temporary ecu but that blue wire is still unhooked i used a cx ecu haha yea i know but what is that blue wire that is unhooked? it was plugged into the outside plug.. not the bigger one the second biggest of the 3... any help would be much appreciated... by the way if ur wonder wtf im doin im getting my ecu chipped
Old Sep 7, 2006 | 12:29 PM
philosofy1's Avatar
it's hard to tell w/o seeing it, but here's a ecu link, hope it works:
https://honda-tech.com/zerothread?id=1171263
Old Sep 7, 2006 | 12:33 PM
Default Re: trying to remove ecu.... help (philosofy1)
A5-INJ3 INJ3 Blue, Battery Voltage with KOEO
is that the 2nd largest one ... solid blue anyone know for sure and what is that cause there was 3 differnt battery voltage ones
Old Sep 7, 2006 | 12:35 PM
is that injector 3?
Old Sep 7, 2006 | 12:39 PM
philosofy1's Avatar
i don't get what you are trying to say. find out what number the wire is and then plug it back into the harness. unless the wire came out of the clamp. if not, just follow the direction on the thread on how to remove them, it'll be basically the same to install it as well.
Old Sep 7, 2006 | 01:23 PM
well i dont really know what im doin obviously lol y u think im postin on here trying to get help... what im trying to do is swap an ecu so i can still have transportation and im getting the ecu in my car chipped
standbackimapro
Nov 17, 2012 08:44 PM
runawayboy
Dec 3, 2008 09:20 AM
clutch33
Apr 29, 2004 04:46 PM
Inkrazy
Mar 7, 2004 10:22 PM
EGHatchy
Aug 2, 2002 07:16 AM
