Power Steering Problem
Old Sep 7, 2006 | 11:11 AM
JohnD1079's Avatar
Default Power Steering Problem
ok, i had my clutch changed about a month ago and after i got it back my power steering does not work. The is fluid in the resivoir, but i am not sure that it is getting pumped through the system. when i open it, it smells burnt. also when i turn i get this werid sound coming from the wheel wells. My friend said that what it sounds like when the fluid isnt getting pumped. Another thing is that now i often lose traction and i get squeaking from the tires. some one said it was alignment, but i dunno. Can anyone help me out here?
I have a 1992 Honda Accord LX.
Old Sep 7, 2006 | 06:25 PM
hondadude's Avatar
Default Re: Power Steering Problem (JohnD1079)
Did they put the speed sensor back into the differential housing of the trans? there are 2 P/S fluid lines that go to the speed sensor. Maybe they got crimped??
When the engine is running you should see the P/S fluid circulate in the reservoir.
When you find thee problem I'd say go ahead and change the P/S fluid with Honda fluid
othreeEX
Honda Civic (2001 - 2005)
Feb 21, 2014 06:14 PM
curtie94
Feb 24, 2012 12:38 PM
old_school_dohcvtec
Jan 18, 2006 03:23 AM
Brian-Brian
Oct 25, 2003 02:29 AM
tintin11
Aug 5, 2003 03:15 PM
