ECU swap.
Would jus changing out my ECU give me more power or nything, without doing a motor swap, maybe be a dumb question but it jus popped in my head and thought it would be a good idea. If it can be done what would be a good ECU to swap for an 86' CRX Si.
don't listen to him. the 92-93 integras are obd1. You'll need an obd0 computer, but honestly I don't think it would benefit very much.
IF you have other mods, like intake, header exhaust, and a cam, then maybe you should look into a way to tune it. Then you should get a 90 or 91 civic computer, since it's chippable, an have someone tune it for you.
I gotta CAI, and a cat back thats not to moded but jus a lil, its the factory EW3 1.5. so if I get the ECU outta 90-91 civic? Would it be "plug in play"?
I've got a PG7 ecu from a DA teg that will work. It runs a little richer and has a higher rev limiter. It may not be a huge improvement now but if you ever plan on boost or nitrous it'll work great. PM if you're interested.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jonsk20Hatch »</TD></TR><TR><TD CLASS="quote">if its vtec try the 90-93 gsr and if non vtec try the ls </TD></TR></TABLE>there are no 90-91 gsr's and the 92-93's are obd1.so
Big Si Guy
Dec 30, 2003 03:55 PM
projectM
Dec 14, 2002 12:05 AM
