Would This be Ok?
Old Sep 7, 2006 | 09:49 AM
hondaricers's Avatar
Default Would This be Ok?
Well my speed sensor went out a while ago but then i couldn't find any replacements in the junk yard in the area around here that has any junked up integra. So my guy (mechanic) gets a prelude and we installed it and it worked but he said it might be like 5mph off due to the transmission ratio from a prelude and integra. Is that true that it might be off? Well let me know! Thanx
Old Sep 7, 2006 | 10:15 AM
blackdelslo's Avatar
Default Re: Would This be Ok? (Jdmturbos)
I dont know much about speed sensors, but my guess is that it is the same as an integra one.
Old Sep 7, 2006 | 12:06 PM
CleanLikeJdm's Avatar
Hype-R Stalker
If it looks the same comparing it to your integra one,
I don't see why it would be 5mph off, if it's the Same size that is.
Old Sep 7, 2006 | 12:16 PM
TunerN00b's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jdmturbos &raquo;</TD></TR><TR><TD CLASS="quote">Well my speed sensor went out a while ago but then i couldn't find any replacements in the junk yard in the area around here that has any junked up integra. So my guy (mechanic) gets a prelude and we installed it and it worked but he said it might be like 5mph off due to the transmission ratio from a prelude and integra. Is that true that it might be off? Well let me know! Thanx</TD></TR></TABLE>
Only reason I can think of it being off is because the Prelude came with larger diameter tires and the sensor measures before the tire.
Old Sep 7, 2006 | 12:52 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Would This be Ok? (TunerN00b)
But the Prelude tranny also has different gear ratios and different final drive ratio. So it may or may not be the same as an Integra.
Old Sep 7, 2006 | 12:55 PM
Ichigo's Avatar
Put it in and drive past those police sign with the speed detection thing. I did that with my gsr and i notice i was 3-5 mph off.
Old Sep 7, 2006 | 02:29 PM
Thanks Foe The help Everyone!!
Old Sep 7, 2006 | 08:15 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Would This be Ok? (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">But the Prelude tranny also has different gear ratios and different final drive ratio. So it may or may not be the same as an Integra.</TD></TR></TABLE>
Gear ratios are irrelavent to the VSS. The VSS simply measures the differential speed.
Check the calibration using a GPS unit. Or search google for "hondahookup manuals", download the appropriate manuals, and calculate the clicks per mile for the Integra and Prelude VSSs compensating for the different tire sizes.
Old Sep 8, 2006 | 05:55 AM
Community Builder
Default Re: Would This be Ok? (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">Gear ratios are irrelavent to the VSS. The VSS simply measures the differential speed.
Check the calibration using a GPS unit. Or search google for "hondahookup manuals", download the appropriate manuals, and calculate the clicks per mile for the Integra and Prelude VSSs compensating for the different tire sizes.</TD></TR></TABLE>
or find a flat stretch of road, set cruise control, and measure time between mile markers. 3600/seconds per mile = actual speed in mph
spoon23_JDizM AkA SpOoN20
Jan 28, 2006 07:10 PM
kvh
Jan 30, 2005 11:29 AM
Understeer
Nov 14, 2003 10:35 AM
UA6 BALLER STATUS
Jun 23, 2003 10:27 AM
