fail-safe relay??
where exactly is this located at? is this the same as the abs relay located under the hood under the abs fuse panel.
hopefully it is different from the abs relay.. any how i have been looking at this abs light far too long.. and the only code that pops up is 54 which is the "fail safe relay" where is this located..
thnx in advance guys..
and i did search fail-safe relay w/ no luck
I repainted the front calipers, I don't know why it shot this specific code. mine is shooting 12, 16, and 81 as well. as for 54, i'm trying to figure that out. I cleaned the wheel sensors, but it still shot the codes. I pulled my cpu, don't know what would have caused that code. I'm going to replace those parts. I checked for shorts in the wiring, everything looks ok. I searched and still don't know what the fail-safe relay is, unless it's the one by the passenger side under the coolant overflow reservoir?
