What size Injectors should I use.
Old Sep 7, 2006 | 07:16 AM
Jacknimble's Avatar
Default What size Injectors should I use.
For my build up, I'm doing a GSR block with the pr3 pistons, and a Pr3 head with crane cams. A rough estimate of around 11.5:1 compression. What i have searched for but have had no luck is, can I still use the stock injectors and the stock pr3 ecu? Or really what the question should be is what do i need as far as bigger injectors, fuel pump, fpr or fuel rail. I'm on a huge budget but i don't want to blow up my motor. Any help from people would be highly appreciated. Thanks.
Old Sep 7, 2006 | 07:18 AM
b19coupe's Avatar
Default Re: What size Injectors should I use. (Jacknimble)
Stock injectors would be o.k. One of the best investments you can make is engine management and tuning.
EGed up from the seat up
17
Jul 2, 2009 12:16 AM
slow_ls
11
Jan 16, 2007 08:46 PM
88crxhfb16
Aug 16, 2005 11:15 AM
bluedelsol
Sep 8, 2002 03:45 AM
VaporTrail
Feb 11, 2002 09:23 PM
