head gasket seaping
Old Sep 7, 2006 | 07:12 AM
austincrx's Avatar
Default head gasket seaping
my head gasket is about 500 miles old, the engine is run fairly, (i don't dog the hell out of it, but rev it up occasionally) it's seaping oil from the front passenger corner. could this be from my head studs stretching? i tightened them all to the specs which are (if i remember correctly) 47lbs.ft and they were tightened in the correct order. should i go with new stock head bolts, or just get ARP head studs? thanks!
Old Sep 7, 2006 | 07:51 AM
GsrTurboCRX88's Avatar
Default Re: head gasket seaping (austincrx)
maybe you need to get your head re surfaced. Did you get all of the old gasket off before you put the new one on?
Old Sep 7, 2006 | 09:49 AM
justseeingifitistaken's Avatar
Default Re: head gasket seaping (GsrTurboCRX88)
head might be warped? also IDK but i torqued my head to 67 ft/lbs i think. its never had any probs
Vtec04
Engine Machining & Assembly
11
Oct 31, 2017 09:26 AM
DaYZeD.1
Mar 28, 2008 09:19 AM
petrv
Apr 12, 2004 12:30 PM
