Suspension & Brakes Theory, alignment, spring rates....
can a chassis be TOO stiff?
Old Sep 7, 2006 | 04:36 AM
an2ny888's Avatar
Default can a chassis be TOO stiff?
a friend of mine was telling me that he felt his car was too stiff after he put on a lot of braces. now my impression is that the stiffer the chassis the better, so that the suspension can work better. h0wever i remember that in rc setups, you get better results if your rc has some chassis flex, so would this also apply to our cars? what do you guys think?
Old Sep 7, 2006 | 09:25 AM
PIC Performance's Avatar
Default Re: can a chassis be TOO stiff? (an2ny888)
A flexy chassis acts like a fifth spring - it reduces the effectiveness of the suspension components, like you said, which is undesirable.
Old Sep 7, 2006 | 10:52 AM
ED7's Avatar
ED7
Default Re: can a chassis be TOO stiff? (PIC Performance)
A chassis could be too stiff for the street for sure. Now a smooth racetrack, you would want the proper chassis stiffness.
Old Sep 7, 2006 | 02:14 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: can a chassis be TOO stiff? (ED7)
If your RC car drove better with a flexy chassis, it was because your suspension was setup poorly (*edit* of setup for a flexy chassis ). A stiffer chassis is better. There is really no negative effects of increasing chassis rigidity (other than increasing weight)...
Modified by 94eg! at 12:46 PM 9/8/2006
Old Sep 8, 2006 | 10:41 AM
turboteener's Avatar
Banned
You can not have a chassis that is too stiff. With a super stiff chassis you can even run softer springs to control suspension movement.
Old Sep 8, 2006 | 10:43 AM
It could not. It is not the job of the chassis to absorb shocks. Its the job of a properly designed suspension to deal with that.
Tyson
26
Dec 29, 2003 04:35 AM
fireant
10
Oct 8, 2003 03:03 AM
JDM_Type-R
Jan 28, 2002 01:52 PM
Flux
Oct 23, 2001 09:38 AM
Ricehornet
Jun 27, 2001 03:15 AM
