need help
Old Sep 7, 2006 | 12:05 AM
EK SQUAD 425's Avatar
Default need help
got a couple questions..
well one day i was going kind of fash, i was smashing going from first-to 2nd and 2nd to 3rd. my friend didn think i can chirp 2nd to 3rd and i did it, but it seemed like i herd and saw some bolts coming off, and ever since then it won't even burn out on 1-2 and the gear seems to be almost popping out. is that a tranny problem? and the only way to fix it is to get a new tranny?
also the guy who did my swap messed up my wiring harness. i jus wanted to know how long would it take to change the headgaskets, change the wiring harness and transmission is that something i could fix fast?
also, my taillights wont work! the headlights work but the tailights won't turn on, and the blinkers won't work....i found out it was the 7.5 fuse but then right when i changed it i tested it out it worked for about 2 seconds then blew again.....any help?
Modified by EK SQUAD 425 at 1:37 AM 9/7/2006
Old Sep 7, 2006 | 12:17 AM
tsdenny's Avatar
Default Re: need help (EK SQUAD 425)
check the clutch line near the slave cylinder
the screw might have fell off
headgaskets ~ you have to take off the head. its going to take forever
wiring harness ~ fast. if your going to swap it with one that works perfectly
transmission ~ takes about 3-4 hours
Old Sep 7, 2006 | 01:54 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: need help (void_accord)
You beat the **** out of your car, and wonder why its broken?
Old Sep 7, 2006 | 08:26 PM
jdm_ej, well thanks for your advice, i redline my car lik a couple a times a week, don't act like you never redlined your '' all motor b18c5 "
OSF3 =]
Aug 27, 2010 11:34 AM
gsr_b20b
Jul 17, 2009 03:53 AM
jdmej2lolo
Oct 17, 2008 09:13 AM
TwoPointZero
Dec 29, 2005 03:19 AM
