Horn used as nitrous activation??
Old Sep 6, 2006 | 09:49 PM
Bull_head360's Avatar
Default Horn used as nitrous activation??
Hey all, im putting in a zex nitrous kit and i want to run the left horn button inline with the WOT signal. i see how they have the power wire connected to that thing that turns with the wheel, and i think the ground is just grounded to the steering wheel/column. do i need to take the steering wheel completely off to get a better view?
i searched already and didnt find anybody's how to on how to do this... any help is appreciated.
Thanks
-Austin
Old Sep 6, 2006 | 11:15 PM
worked on it some more, i just dont see how i can do this without rapping a bunch of wire around the column when i turn
Old Sep 7, 2006 | 12:28 AM
bump before bed
Old Sep 7, 2006 | 11:38 AM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
Default Re: (Bull_head360)
take the wire off the horn (the actual horn under the hood) put a 3 position toggle switch inline ( one position will activate horn , one position with activate nitrous) simple
Old Sep 7, 2006 | 11:45 AM
2quikmotorwerks's Avatar
Default Re: (WHITFIELD-TUNED)
3 way toggle would be the way to go cause both horn buttons go to the same horn ring under the steering wheel and is impossible to seperate the horn button signals
Old Sep 7, 2006 | 03:59 PM
DYNO-PRO
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WHITFIELD-TUNED &raquo;</TD></TR><TR><TD CLASS="quote">take the wire off the horn (the actual horn under the hood) put a 3 position toggle switch inline ( one position will activate horn , one position with activate nitrous) simple </TD></TR></TABLE>^^^^^
Old Dec 2, 2006 | 07:58 PM
Cali4niaEk9's Avatar
I WANT 2 GO BIG ON NITROUS!!!!!!!!!! i want to know what do i change or do to Use as much NITROUS as i can On Race Gas on the Track on my All motor Setup!!!!!!!!
B20b block Stock Sleeves Block Guard 84.5mm Arias 11:8:1 Piston
Rods are Pinned (stock)
Type R water/Oil Pump
Ctr Pully
Custom Head Gasket for High Compression
B16 Head Ported/Polish Full Omni Valvetrain
Milled HEAD 440Injectors
Jun 3's or Have Custom DH RACING CAMS
Rage Header 2.0 Big Tube
Want to Know what Spark Plugs to run? Wat to Change !!!!
Wats biggest i can go On Squeez?
What System To BUY???????????
Old Dec 2, 2006 | 08:47 PM
Boots's Avatar
Default Re: (Cali4niaEk9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cali4niaEk9 &raquo;</TD></TR><TR><TD CLASS="quote">I WANT 2 GO BIG ON NITROUS!!!!!!!!!! i want to know what do i change or do to Use as much NITROUS as i can On Race Gas on the Track on my All motor Setup!!!!!!!!
Ctr Pully
What System To BUY???????????</TD></TR></TABLE>
omg are you serious??and you totally just jacked this dudes thread
Old Dec 2, 2006 | 09:21 PM
screaminhatch's Avatar
bump, douche
Old Dec 4, 2006 | 04:51 PM
is he retarded? /thread
b18moder
Jun 1, 2008 09:03 PM
Bull_head360
34
Sep 11, 2006 04:14 PM
Bull_head360
Sep 11, 2006 03:33 PM
accordfreak
Audio / Security / Video
Aug 18, 2006 07:39 PM
98GeeYes-Are
10
May 6, 2004 11:36 PM
