Front brake caliper problem
you need to replace the rack end bushing in your steering rack. i promise you. its a $10 peice of plastic that is worn out, and is most likely the source of your vibration. here you go https://honda-tech.com/zerothread?id=1387079
you may also just make sure the slider bolts on your calipers are well greased. that can also cause your brakes to be grabby, but deffinetly the rack end bushing before you go any further.
EFing8
10
Aug 2, 2016 12:08 PM
*skittles
Honda Civic (2001 - 2005)
17
May 25, 2009 12:52 PM
