GSR Skunk2 manifold
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY »</TD></TR><TR><TD CLASS="quote">You can get an intake for a LS integra but I would suggest getting one from a Type R.
why?
</TD></TR></TABLE>why?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lVlemphizStylez »</TD></TR><TR><TD CLASS="quote">why?</TD></TR></TABLE>
If you are going to modify the breathing characteristics of your engine setup, you might as well go bigger.
If you are going to modify the breathing characteristics of your engine setup, you might as well go bigger. </TD></TR></TABLE>
and you feel they dont make a 3inch diameter ls intake??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lVlemphizStylez »</TD></TR><TR><TD CLASS="quote">and you feel they dont make a 3inch diameter ls intake??</TD></TR></TABLE>
The typical off the shelf models for the base model, LS, Integra applications feature 2.5 inch diameters.
Example: AEM
However, if a person wants to buy a generic intake such as the ones found on ebay, those typically are all 3 inch.
Example: AEM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WalkerGSR1 »</TD></TR><TR><TD CLASS="quote">I wanted to know cause the gsr stock manifold is angled differently, the skunk is more similar to type r intake manifold so i was thinking order a type R intake.</TD></TR></TABLE>
its angled the same as an LS intake manifold as well...Whichever you can get cheaper go with...same diameter ls and same diameter type r..i dunno something tells me ppl will hike prices up just because its for the hype r..and some ricer will feed into it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lVlemphizStylez »</TD></TR><TR><TD CLASS="quote">its angled the same as an LS intake manifold as well...Whichever you can get cheaper go with...same diameter ls and same diameter type r..i dunno something tells me ppl will hike prices up just because its for the hype r..and some ricer will feed into it</TD></TR></TABLE>
LS diameter is NOT the same as Type R.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY »</TD></TR><TR><TD CLASS="quote">You can, but it's meant for the Type R application.
As I stated before, branded intakes for LS application typically are 2.5 inch in diameter. </TD></TR></TABLE>
i just removed my old ls intake...at 3 inch diameter...i will mail it to you so you can frame it as proof...im done talking...
OP: You can buy a 3 inch diameter ls intake...in all likelihood it might even be cheaper than the type r...but like i said go with whatever is cheaper
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lVlemphizStylez »</TD></TR><TR><TD CLASS="quote">i just removed my old ls intake...at 3 inch diameter...i will mail it to you so you can frame it as proof...im done talking...
OP: You can buy a 3 inch diameter ls intake...in all likelihood it might even be cheaper than the type r...but like i said go with whatever is cheaper</TD></TR></TABLE>
What brand is it?
What brand is it?
What brand is it? </TD></TR></TABLE>
ebay special...ill save that 150 extra bucks and put it to something that will actually make my car faster...
Thank you for proving my points.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY »</TD></TR><TR><TD CLASS="quote">The typical off the shelf models for the base model, LS, Integra applications feature 2.5 inch diameters.
Example: AEM
However, if a person wants to buy a generic intake such as the ones found on ebay, those typically are all 3 inch. </TD></TR></TABLE>
Example: AEM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WalkerGSR1 »</TD></TR><TR><TD CLASS="quote">You guys are making this a hard decision. lol</TD></TR></TABLE>
Just get what you want.
I highly suggest AEM or Comptech Icebox.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WalkerGSR1 »</TD></TR><TR><TD CLASS="quote">Does the comptech icebox give the same sound as aem cold air</TD></TR></TABLE>
Completely different sound. The comptech sounds like your stock intake with the resonator removed. A lot more quite compared to the AEM.
here...
http://www.ebay.com
look up LS intake and 3inch piping.
$40shipped tops.
you wont find a ebayDM ITR intake... i looked myself. u can only find AEM and other name brand.
thats if u want the bang for ur buck way to do it. my AEM GSR CAI fits my skunk2 IM just fine.
http://www.ebay.com
$40shipped tops.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WalkerGSR1 »</TD></TR><TR><TD CLASS="quote">So i could use my same GSr intake. Ight thanks</TD></TR></TABLE>
you could but it doesnt look right nor fit 100% perfectly. Some people have had their gsr intake hit or rub against the hood while its shut.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iH8RICERZ »</TD></TR><TR><TD CLASS="quote">you could but it doesnt look right nor fit 100% perfectly. Some people have had their gsr intake hit or rub against the hood while its shut.</TD></TR></TABLE>
it does look a little odd, but the only thing i had rubbing against my hood was the OEM GSR throttle cable bracket.
