b series timing cover question...
ok i dont have the inner and outter top timing belt cover on my lsvtec... the head is a 92jdm b16.. Do i need to have the inner timing belt cover for the out timing belt cover to work?
anylinks or pictures would help!, thanks
thank you, do u have any links or picture to support your comment, i was told other wise by my friend who has the same part, and is lazy and doesn't want to take the cam gears off because of this...
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sleeper Style »</TD></TR><TR><TD CLASS="quote">I have this one. It is hard to tell, but the back cover is non-existent. I would take pictures now, but I don't even have the outer cover installed at the moment.
thanks for the picture.. what kind of motor is that lsvtec or what? and why is your outer cover off? how many Bolts do i need to buy? just 2 correct? will ones from a SOHC work?
</TD></TR></TABLE>thanks for the picture.. what kind of motor is that lsvtec or what? and why is your outer cover off? how many Bolts do i need to buy? just 2 correct? will ones from a SOHC work?
this is what im working with right now, as you can see my valve cover is cut the same way.. and You can also see one bolt hole in the picture? so what is the purpose of the inner timing belt cover? and Why do so many people just take them off... i never heard of a rubing issue. If it was bolted down all the way. and not warped..?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY »</TD></TR><TR><TD CLASS="quote">Looks like sleeperstyle likes to show off his rusted stock cam gears
hey i just sold my adjustable ones and have my stockys on righ tnow too
, they rock.
</TD></TR></TABLE>hey i just sold my adjustable ones and have my stockys on righ tnow too
, they rock.
I sure do...and I am proud of them.
It is a GSR. My cover is off because I just replaced my lost motion assemblies and forgot to put it on, and once I realized it, the valve cover was already put on and torqued down.
</TD></TR></TABLE>I sure do...and I am proud of them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY »</TD></TR><TR><TD CLASS="quote">The purpose of the inner timing belt covers are to prevent exterior dirts and liquids from entering the chamber where the timing belt lies. Every little bit of safety adds up
It is a GSR. My cover is off because I just replaced my lost motion assemblies and forgot to put it on, and once I realized it, the valve cover was already put on and torqued down.</TD></TR></TABLE>
so to install this i will need to take my valve cover off, it looks like it just barely touch's it on the bottom 2 corners, if it even does.. sence mine is probably cut just a Little bit different than yours will i have any fitment issues?
</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sleeper Style »</TD></TR><TR><TD CLASS="quote">
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by POE »</TD></TR><TR><TD CLASS="quote">so to install this i will need to take my valve cover off, it looks like it just barely touch's it on the bottom 2 corners, if it even does.. sence mine is probably cut just a Little bit different than yours will i have any fitment issues?</TD></TR></TABLE>
Yeah, it won't go in there unless the valve cover is off. I tried, but it won't snap into place.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by POE »</TD></TR><TR><TD CLASS="quote">and on a SIDE NOT, thanks BTW, This head is from a 92 jdm b16, if i order a 99-00 si outcover, it will work correct?</TD></TR></TABLE>
Yes.
You will need to order one from a gsr/b16/typer.
Yes.
Yes.
You will need to order one from a gsr/b16/typer. </TD></TR></TABLE>
ohh i thought the gsr's and type r's were a bit different than the b16's... shows how much i know..
Yes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by POE »</TD></TR><TR><TD CLASS="quote">hmm i guess imgonna buy one, i hope i dont have to go for the inner also...</TD></TR></TABLE>
You don't really have to...unless you deal with a lot of gravel that may find its way up to the timing belt and wreck havoc on your timing belt. I have been running mine for well over a year without that inner piece (mainly because it was ripped to shreds somehow) and it hasn't had a problem yet.
idriveadelsol7
Dec 18, 2005 12:23 PM
