(Already searched) Does anyone have a good write up on skunk2 intake manifold.
Old Sep 6, 2006 | 02:48 PM
ls1tjw's Avatar
Default (Already searched) Does anyone have a good write up on skunk2 intake manifold.
Does anyone have any write ups for skunk2 intake manifold for an h22a4 like where all the vac hoses go and things like that the instructions suck to say the least! Also my manifold has a place for a fitting or something i dont know what but its on the runner closest the driver side #1. Any help would be great.
Old Sep 17, 2006 | 06:16 PM
ls1tjw's Avatar
Default Re: (Already searched) Does anyone have a good write up on skunk2 intake manifold. (ls1tjw)
does anyone have one.
Old Sep 17, 2006 | 06:25 PM
l2yanE's Avatar
can i ask one question first? what do you have done to your car? you do realize that a nearly stock h22 will lose power with that manifold right?
Old Sep 19, 2006 | 06:20 PM
ls1tjw's Avatar
Default Re: (Already searched) Does anyone have a good write up on skunk2 intake manifold. (l2yanE)
lets just say its no where near stock. So do you have a write up?
Old Sep 20, 2006 | 05:49 AM
Mykizism's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ls1tjw &raquo;</TD></TR><TR><TD CLASS="quote">lets just say its no where near stock. So do you have a write up?
if its no where near stock.. then why dont you have the knowledge of installing a simple intake manifold??
Old Sep 20, 2006 | 08:56 AM
ranta18's Avatar
Default Re: (Already searched) Does anyone have a good write up on skunk2 intake manifold. (Mykizism)
Dam haters. Chill out. If you can't answer the guy's question why respond.
If its on the side of the runner thats for the Intake Air Temperature sensor. It should have a hole and then two threaded holes next to it. You can see it in this picture:
Old Sep 20, 2006 | 09:19 AM
98TypeSH's Avatar
Default Re: (Already searched) Does anyone have a good write up on skunk2 intake manifold. (ranta18)
A vac plug is a vac plug.
Old Sep 20, 2006 | 11:05 AM
98vtec's Avatar
moderator emeritus
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by l2yanE &raquo;</TD></TR><TR><TD CLASS="quote">can i ask one question first? what do you have done to your car? you do realize that a nearly stock h22 will lose power with that manifold right?</TD></TR></TABLE>
lose bottom end but will gain peak........take that statement as you will..
Old Sep 20, 2006 | 12:05 PM
ls1tjw's Avatar
Last time I checked this forum is here for people to ask questions and get help from other people that have had these problems before. So unless you have something to share in the way of informed knowledge keep your thoughts to yourself. Thanks!
Old Sep 20, 2006 | 12:14 PM
ranta18's Avatar
Is it the IAT sensor like I said?
Old Sep 20, 2006 | 12:51 PM
ls1tjw's Avatar
Yes thank you for actually helping me there should be more people on here like you. Thanks again!
Old Sep 21, 2006 | 02:43 PM
94vtirozguy's Avatar
i started my install last night. The Skunk instructions are not the best but i will let you know how i go.
Old Sep 21, 2006 | 09:48 PM
TylerC161's Avatar
damn dude.. i did mine, but, i took it all apart for the turbo project..
It also depends if your using EGR or not when hooking up lines..
Old Sep 22, 2006 | 03:25 AM
i am upto putting the IM in the car, however i notice the IM is rubbing against the ABS up top so it not slipping over the 10 bolts easy up one side... biatch!
Modified by 94vtirozguy at 11:47 PM 9/22/2006
sung
Sep 28, 2007 08:21 PM
Mighty Mintos
Jun 10, 2003 10:31 AM
EJ8 Kenobi
Aug 2, 2002 11:40 PM
