What turbo for d16z6...max goal of 300whp
Old Sep 6, 2006 | 12:31 PM
broketuner-Sol_Si's Avatar
Default What turbo for d16z6...max goal of 300whp
Well as some of you know I got burned on a BB t28 thanks to a wannabe thug on here(http://hondamarketplace.com/zerothread?id=1727088). Well I've got a few things up for sale/trade and have recieved quite a few offers to trade for turbos. Here are the ones I think would be good(although not neccessarily support my max goal) t25, t28, t3(I don't know what A/Rs to go with though) or the t3/t4 B(again no clue on what sizes to go with). If I were to get a t3 or a t3/t4b what A/Rs would you guys reccomend, I looked through the single slam thread, but a majority of those guys aren't using those turbos. here are my plans for the motor:
https://honda-tech.com/zerothread?id=1727010
Old Sep 6, 2006 | 12:47 PM
nerdsports's Avatar
I have a t3/to4e .48exh 50trim and I made 273whp @ ~12.5-13psi.
You can go with a 57trim which flows slightly better or wait for someone to suggest some $800-1500 BB turbo.
Old Sep 6, 2006 | 01:04 PM
Boostage's Avatar
Default Re: (nerdsports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nerdsports &raquo;</TD></TR><TR><TD CLASS="quote">I have a t3/to4e .48exh 50trim and I made 273whp @ ~12.5-13psi.
You can go with a 57trim which flows slightly better or wait for someone to suggest some $800-1500 BB turbo. </TD></TR></TABLE>HHAAH. this is so true
but my vote is for any spec t04b if you have to go with a t3/t4 hybrid.
Old Sep 6, 2006 | 01:07 PM
yeah I've offically decided I'm done with bal bearing turbos, I found out the every 50-75k miles they need a complete new center section which is almost as much as the turbo itself.
Old Sep 6, 2006 | 01:11 PM
Boostage's Avatar
Default Re: (broketuner-sol_si)
50-75k is 4 - 6 years if you drive the average of 12k a year. a thrust bearing will probably need a rebuild also. hell your motor might need a rebuild..
oh and again.. t04b
Old Sep 6, 2006 | 01:37 PM
Kelly.'s Avatar
I've quit using this account
t3t4e
50 trim or 57 trim if you plan to grow later
63 turbine
3 in DP
= 300 whp on a d16 no problem.
Paperweight
Aug 16, 2005 12:43 PM
Skank_aSS_Dara
May 9, 2005 10:53 AM
onetwothree
Sep 23, 2004 06:23 AM
extrmeboost
Feb 6, 2003 07:29 PM
