took pics of my motor in my car finally!! 1"deckplate....my hoods gettin right hacked up lol...
took pics of my motor in my car... probly gotta cut a hole in the hood for the motor
i guess you guys know what all my stupid posts were about now
AND HERE IS THE 1960 LB BEAST ITS SITTING IN
hopefully it will be running soon
Modified by B18 CYA at 9:32 PM 9/6/2006
Modified by B18 CYA at 9:42 PM 9/6/2006
Modified by B18 CYA at 10:50 PM 9/6/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 »</TD></TR><TR><TD CLASS="quote">quick question about it, just wondering, do you use two oem or oem style head gaskets or is it custom stuff??</TD></TR></TABLE>
if you mean headgasket its just 1 cometic 85mm .030".
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Furyof4 »</TD></TR><TR><TD CLASS="quote">Niiice...Care to share any specs?</TD></TR></TABLE>
block:
85mm gsr block
89mm crank
custom 13.5:1 7cc dome arias pistons
custom cunningham 6.3770" ultra lite rods
.980" deckplate
head:
gsr head
toda c cams
.5mm oversize in/ex valves
REV stainless valves/springs
crower retainers
ported skunk2 mani
edelbrock 70mm throttle body
bdl comp fuel rail
ported locally by house of hybrids
block:
85mm gsr block
89mm crank
.980" deckplate
head:
gsr head
toda c cams
crower retainers
ported skunk2 mani
bdl comp fuel rail
very interesting. i would almost just have someone help you fab up some motor mounts to drop it down a little before i ran with a VC sticking out of my hood though. or run some kind of smokey and the bandit cowl.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VenGeanceDrag »</TD></TR><TR><TD CLASS="quote">So you used the Ford timing belt with factory water pump?</TD></TR></TABLE>
nope. i am getting a custom plate with adjustable gear made for the water pump, then running an electric one, so that i can use the stock GSR belt.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94 si hatch »</TD></TR><TR><TD CLASS="quote">what kind of power you looking to make?</TD></TR></TABLE>
if i hit 250whp i would be more than happy.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SaturdayNightWrist »</TD></TR><TR><TD CLASS="quote">very interesting. i would almost just have someone help you fab up some motor mounts to drop it down a little before i ran with a VC sticking out of my hood though. or run some kind of smokey and the bandit cowl.</TD></TR></TABLE>
well i live in canada so we dont have those kind of law about anything sticking out of the hood. plus it is kept in a garage so i dont care
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VenGeanceDrag »</TD></TR><TR><TD CLASS="quote">I thought I saw a pic (thats no longer posted) that had a factory pump and timing belt around the cam gears and pump, thats all. Good luck.</TD></TR></TABLE>
yeah that was one of the belts i tried that skipped like 5 teeth when i cranked it over..good thing i had no fuel going to the motor..
by looking at that sideview its just not adding up for me. seems like if you dropped it an inch to stock gsr deck height itd still hit. also, it seems like a gsr would have more than an inch before it hit the hood so youd jsut have to remove the webbing under the hood. that thing jsut looks way way up there like an h2b.
it take it this motor is an excersize in R/S ratio benifits?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SaturdayNightWrist »</TD></TR><TR><TD CLASS="quote">by looking at that sideview its just not adding up for me. seems like if you dropped it an inch to stock gsr deck height itd still hit. also, it seems like a gsr would have more than an inch before it hit the hood so youd jsut have to remove the webbing under the hood. that thing jsut looks way way up there like an h2b.
it take it this motor is an excersize in R/S ratio benifits?</TD></TR></TABLE>
Yeah, my stock gsr I used to have in it was hitting the hood already with the webbing cut out. I havnt tried the hood yet, but Im 100% sure there will be a nice big hole for the VC in it
Rod/Stroke ratio on it is 1.82. It should be a high revver, My buddy will be borrowing me his skunk2 cams to also try out on it and see what it can pull with more of a topend cam.
ive always been very very interested in deck plating, if you could post details on how it is on the block, or link me to the thread if you already have. i didnt look super closely but it doesnt look welded so im assuming it has countersunk bolts? how do the rings like that little line it has to leave? ive seen deckplating before, i know nhra outlawed it a few years ago and you dont hear a whole lot about it anymore. fill us (me) in if you would, aye?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SaturdayNightWrist »</TD></TR><TR><TD CLASS="quote">ive always been very very interested in deck plating, if you could post details on how it is on the block, or link me to the thread if you already have. i didnt look super closely but it doesnt look welded so im assuming it has countersunk bolts? how do the rings like that little line it has to leave? ive seen deckplating before, i know nhra outlawed it a few years ago and you dont hear a whole lot about it anymore. fill us (me) in if you would, aye?</TD></TR></TABLE>
Yeah its not welded it has coutersunk bolts, the deckplate is stuck on top and then the sleeves are put in after so that it is smooth. Other than and the fact that you need custom rods made, I dont know too much else.
Heres how the motor looked before the head was on, you can see where it is bolted on and how the sleeves were done.
Modified by B18 CYA at 10:20 PM 9/6/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris22215 »</TD></TR><TR><TD CLASS="quote">Tucked radiator
wow
hahah yeah, its the only thing that fit, half rad wouldnt even go in there
wow
</TD></TR></TABLE>hahah yeah, its the only thing that fit, half rad wouldnt even go in there
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18 CYA »</TD></TR><TR><TD CLASS="quote">hahah yeah, its the only thing that fit, half rad wouldnt even go in there
are my eyes decieving me or is that a neon radiator? i just got one and it looks short enough that if mounted on an aftermarket x member in a rex it will tuck under the support iwth a remotely mounted cap.
so youre saying the block is sleeved with longer sleeves to make up the difference in height, so the water jacket and everything stays the same? that makes more sense
dont suck in any pumpkins or little kids with that TB
</TD></TR></TABLE>are my eyes decieving me or is that a neon radiator? i just got one and it looks short enough that if mounted on an aftermarket x member in a rex it will tuck under the support iwth a remotely mounted cap.
are my eyes decieving me or is that a neon radiator? i just got one and it looks short enough that if mounted on an aftermarket x member in a rex it will tuck under the support iwth a remotely mounted cap. </TD></TR></TABLE>
Nope, Its a custom made rad by a local company here. Neon rad doesnt fit in there with the RMF header.
so youre saying the block is sleeved with longer sleeves to make up the difference in height, so the water jacket and everything stays the same? that makes more sense </TD></TR></TABLE>
Yeah, Basically the sleeves are exteneded past where they are originally and up the to the top of the plate. Everything else is the same still.
Time to set a new all motor record at the dyno and the track
. The build looks awesome, only downer might be having to use race gas but its gonna be one hell of a beast
