launching at 4500 with slicks?
Old Sep 6, 2006 | 11:41 AM
ALL IMPORT's Avatar
Default launching at 4500 with slicks?
well i got me a set of lensos 13 with 22 mh slicks im making 370 right now in my teg. my 2step is set at 4500 for my radial drags & wondering if i put my slicks on will it hurt the tranny or axels with the slicks due to the lower rpm or should it go up. also still have stock axels.
Old Sep 6, 2006 | 11:45 AM
1Quikgsr's Avatar
i would launch around 7k
Old Sep 6, 2006 | 11:55 AM
ALL IMPORT's Avatar
Default Re: (1Quikgsr)
i tried 5800 with the radial drags & it just roasted the tires. i dont build any boost untill 5500 & when boost comes in it hits hard. big turbo. but maybe slicks act totally diffrent.
aslo do u want slicks to spin a little when u are launching to keep from breaking things
Old Sep 6, 2006 | 12:42 PM
ATYPR's Avatar
Default Re: (ALL IMPORT)
Drag radials are not like slicks. Look at my sig. LOL!
Old Sep 6, 2006 | 01:25 PM
nsxmatt's Avatar
I used to launch at 8k on a sticky track. 5k won't cut it, slicks are not radials or even close.
Old Sep 6, 2006 | 04:52 PM
ExospeedAMcrx's Avatar
Default Re: launching at 4500 with slicks? (ALL IMPORT)
you have to launch higher RPM on slicks so it grabs hard out of the hole. If you dont, it will just bog out of the hole and you might as well not run slicks at all.
If you are worried about breaking at the launch, then you may want a little spin out of the hole. Pump up the slicks a little more than usual so its not so "gummy/flat" look. Maybe about 12-14psi. You'll still have to go higher than 4500 rpm or else your too low rpm to get a good launch.
Old Sep 6, 2006 | 05:07 PM
boostedcivicsir's Avatar
Mr. Badwrench
8200 preloaded here. preloading is key.
http://www.sportcompacttuning.com/mikey1072split.wmv
right click save as.
Old Sep 6, 2006 | 05:25 PM
PeakBoost's Avatar
B*A*N*N*E*D
Default Re: (boostedcivicsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">preloading is key.
you want to avoid as much shock to the drivetrain as possible when transferring power
Old Sep 6, 2006 | 07:29 PM
ALL IMPORT's Avatar
Default Re: (Ken Peak)
so the best way is to just drag the the clutch a little while using the e-brake?
also are u peepz using a low boost for 1st or just going all out?
Old Sep 6, 2006 | 07:36 PM
Mr. Badwrench
yes ride the clutch while dragging the e-brake. well yeah. find where the clutch starts to grab but still can be held back with the e-brake.
and in that pass as soon as the e-brake hit the bottom, i was at 28 psi. thats why it spun so bad. i have a new setup, the old was a blitz dual sbc non staged controller, and now have the ITS controller and am still working on launch settings.
Old Sep 7, 2006 | 03:28 AM
ALL IMPORT's Avatar
i was thinking on buying greddy low boost wireless deal. using that i will be able to launch at the most 14psi. only because with my set up the turbo wont go any lower.
so it will depend on what the 2setp builds up to that point. & with the 14psi that will be launching around 350whp give or take a little
is that actually to much power for a launch or ideal rang.
or does it have to do with tire size ect...
Old Sep 7, 2006 | 03:56 AM
Mr. Badwrench
just a 2 step on my car with a .9 bar spring, at 8200 builds 7-8 psi.
Old Sep 7, 2006 | 11:17 AM
ALL IMPORT's Avatar
do u use antilag?
Old Sep 7, 2006 | 12:01 PM
Mr. Badwrench
no anti lag yet.
Old Sep 7, 2006 | 12:37 PM
B18c1turboedEK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">8200 preloaded here. preloading is key.
right click save as.</TD></TR></TABLE>
Arent you running kinda lean? i saw the A/F staying at 14.5
Old Sep 7, 2006 | 04:18 PM
ALL IMPORT's Avatar
Default Re: (B18c1turboedEK)
i thaught the same.
from what ive seen once u go over high 13's in the afr you loose a little in the top end
Old Sep 7, 2006 | 04:21 PM
Mr. Badwrench
disclaimer didnt make it to the vid link.......when originally posted, the sensor died. was 11.4 under 27 psi night before, the sensor died coming off of the trailer. i know i know.....isallgood. trust me it isnt that lean.
Old Sep 7, 2006 | 05:05 PM
turbocrex's Avatar
That vid is awesome with the split screen.
Old Sep 7, 2006 | 05:20 PM
Mr. Badwrench
Default Re: (turbocrex)
yeah when you dont have datalog, you do what you can he hee.
Old Sep 7, 2006 | 05:35 PM
ALL IMPORT's Avatar
ha ha thats funny.
a new way to datalog, in car camera
on another note i tried some launch practic in front of my house & this is what i came up with.
if i stage one light i can just drag the clutch so the car bairly creeps into the second light hit the e-brake & mash the gas while keeping the clutch at the same spot so its not burning up but enought to put tention on the gears &,let-r-rip!
werd up, going to go play tonight
Hondaruss
Nov 8, 2007 02:55 PM
