"True" Electric Water Pump?
NOTE: For street/strip cars...
Most of the electric water pump kits I have seen are installed in the lower radiator hose with the pump pushing the water towards the thermostat. Usually 2 small holes are drilled in the thermostat to keep the pump from burning up. The electric pump flows the water in the same way as the stock pump, but the stock pump constantly circulates the water in the motor while the electric one will only circulate the water in the motor if the thermostat is open. A restrictor plate could be used, but most people have found it cools too much and they need to shut the pump off, then turn it on, etc. This can create hot spots in the motor. A "true" electric pump would flow like the stock one.
To do this could you cut the metal water tube on the back of the block and run the pump there? This could be as simple as two "T" fittings with a block off bewteen them. Hoses from the "T" fittings would run to the pump. Thoughts?
I see what you did for the water pump side, but what about the thermostat housing side? Same thing?
60 views and no other comments?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ranta18 »</TD></TR><TR><TD CLASS="quote">I see what you did for the water pump side, but what about the thermostat housing side? Same thing?
60 views and no other comments?</TD></TR></TABLE>
What about running the pump on a voltage regulator just to slow down the flow?
Modified by skunked at 8:10 PM 9/8/2006
I did some looking around and a few threads stated the GSR water pump flows 150 quarts/min at 6,000 rpm. Thats 37.5 gal/min. The Meziere kit is a 20 gal/min pump. Hmmm... A single small hole in the thermostat may still be needed to ensure it is cooled enough.
here is a pimp setup.........im using it right now along with the electronic controller.....
http://www.daviescraig.com.au/
here's one that was just made for my car. Mike@t1 made it for me, saved me some time. The tube in the middle is not hollow it just makes the tube 1 piece. The coolant will flow around to the GE waterpump then back to the otherside via rubber hose.
I ran a similar pump / split pipe setup on the back of my H-series with a factory thermostat for a few years on a daily driver. I never had any problems at all. I just cut all the fins off of my factory pump since there was no "kit" available at the time. Just make sure you have a light fuse or something in place so if it ever fails you know about it.
Buy this davis craig pump and through your mecanical thermostate in the garbage..
http://www.daviescraig.com.au/Electr...0-details.aspx
Here is the manual for those that want to read exactly how it works.. http://www.daviescraig.com.au/Images...ecs%202009.pdf
What would be sweet is an electric water pump that mounts in the factory location. Would that be that hard? If the pump was able I dont see why the guys with ecu's that allow inputs to vary the speed of the pump by rpm or coolant temp. Drill out some holes in the timing cover for the wires to go through. But you guys are messing with the back of the block so I am guessing there is more room back there?
what would be cool is if someone made a replacement water pipe like the one above. put AN fittings on and make a plug and play kit for lazy asses like myself. hahaha
Jason
Someone needs to make these and make some money cuz you know you have at least 2-3 of these laying around your shop when your in the honda game lol
i dont give two ***** about Nhra/nopi. Im running the pump and i will run in those events whenever it changes. I bet if people didn't run in those classes something would change.
maybe someone is....
, *whispering Mike@t1 Mike@t1* you gotta be willing to pay for it though.
