M-3 mirror instruction help
I just bought a 1992 accord and a set of M-3 mirrors from E bay and there are no instructions there are 6 wires
white +
blue park Lp
black -
mirror motors
green ?
yellow ?
white ?
white +
blue park Lp
black -
mirror motors
green ?
yellow ?
white ?
the instructions are gone because no one wants you to install those horrific mirrors on your cars
Instructions should read as follows:
1. Remove From box
2. Place on Ground Near Rear Tires
3. Get in Car
4. Remove From Park
5. Put in reverse
6. apply even force to Gas Pedal
7. Grab Broom And Dust Pan
8. Incinerate Parts in Near By Fireplace
Thank Yous are welcomed
1. Remove From box
3. Get in Car
4. Remove From Park
5. Put in reverse
If you paid with paypal, file item not as described and go for a full refund.
They are as they said, worth adding plastic to your tires.
More then likely they are cheap imatations of the real M3 mirrors (hence no instructions)
Watches out for your electrical system if you do manage to get them installed over getting a refund.
(sees another accord go up in smoke over cheap imatation FAKES)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xamraci »</TD></TR><TR><TD CLASS="quote">the instructions are gone because no one wants you to install those horrific mirrors on your cars </TD></TR></TABLE>
They're not that horrific.....on the right car.
Isn't the whole m3-mirror-on-my-honda-thing so like 2001??
hahaha^^^
REAL M3 Mirrors on those cars from that place, I think they used to make planes or something...e30, e36, e46, e something or another...those people...you know what I am talking about...
Yes...ON an M3 they look good, but I wont give any other car a chance to enjoy their beauty on the car they came from
It turned out not to be a waste the motors work great and I used the plugin from a set of junkyard mirrors if anybody buys a set be prepared to do a little tech work with a battery and a multi-meter
Care to share the wiring diagram? Where or what did you wire to, if you don't mind? I purchased the same and my original mirrors are cashed. Let me know what you found out if you don't mind.
Thanxx
Thanxx
here is whar i got I had to got to a Chilton manual for the wiring for my car
left side:
white to constant
black to ground
blue to park lp red/ black
or blinker green/ blue under dash
yellow / black yellow
blue / white white
yellow / orange Green
Right Side:
white to constant
black to ground
blue to park lp red / black
or blinker green/yellow under dash
blue/ black yellow
blue/ white white
blue/ green Green
hope i could help if your wires dont match on the mirrors use a multimeter set to ohms
left side:
white to constant
black to ground
blue / white white
Right Side:
white to constant
black to ground
blue/ black yellow
blue/ white white
blue/ green Green
ddrymkiew
Honda Civic (2001 - 2005)
Jan 19, 2008 11:24 PM
