JDM h22a starting issues
Old Sep 6, 2006 | 07:00 AM
JDMCLUDE's Avatar
Default JDM H22A STARTING ISSUES PLEASE HELP!!!!! MADAY
What's up peoples, it's been a sec since I have been on the forum. I need some guidence. I successfully swapped an h22a into my accord a couple years back. The only engine code I was throwing was EGR related. Fastfowarding to this past year. As it got cold my car did not want to start. I would take the plugs out and they would be wet from gas. I wasn't sure if some sensor on the car was telling the car to dump fuel when it didn't need to. Since then to try and correct the problem using advice and gut feelings, I replaced or rebuilt the entire distributor, coolant temp sensor, fast idle valve, spark plug wires, fuel pump, fuel filter spark plugs, oil pressure sensor, ECU and I am still having this starting issue (only when the temp begins to drop). The only known issues I know are the egr valve according to the ecu may be having some issues (low/high lift something) and I have a small crack in my exahust manifold. Both of these issues I think are separate from my starting problem. Has anyone experienced cold start issues that they were able to resolve? If so I am in dire need of help since winter will be fast approaching in months to come. Thanks Paul
Old Sep 6, 2006 | 11:00 AM
mgags7's Avatar
what injectors and ecu are you running?? do you have a resistor box on there if theyre the peak&hold obd1 h22 injectors??
JDMCLUDE
Sep 6, 2006 04:38 PM
fizzbob7
Jul 8, 2003 05:14 AM
Ri5e
Jun 28, 2003 10:25 AM
Chubs
Mar 17, 2003 02:56 PM
