Need Help ASAP
I have a 95 Teg LS, I'm having trouble starting the car. when i try to turn it on it makes this clicking sound. i replaced the battery, the spark plugs and wires but still nothing. i have a feeling it's the starter or the distributor cap & rotor. was wondering what are your opinions
Appreciate all the help
Thank You
Thank You
Clean and Tight hard those batterys conections ( + and - )! WILL WORK!!!!!!!! If you did that do it again and harder!
Here is nothing to do with the spark plugs and wires... this is BAD Conection!
Modified by red eye teggy at 10:43 AM 9/6/2006
Here is nothing to do with the spark plugs and wires... this is BAD Conection! Modified by red eye teggy at 10:43 AM 9/6/2006
That clicking is the starter more han likely it isn't getting enough juice to turn over...as stated before clean the terminals make sure the battery is charged and check all your grounds(thermo housing, tranny-frame-battery, and valve cover) you can also use a multimeter to check to make sure you didn't get a junk battery, should be around 12-13v across ther terminals
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Loserkidwac »</TD></TR><TR><TD CLASS="quote">That clicking is the starter more han likely it isn't getting enough juice to turn over...as stated before clean the terminals make sure the battery is charged and check all your grounds(thermo housing, tranny-frame-battery, and valve cover) you can also use a multimeter to check to make sure you didn't get a junk battery, should be around 12-13v across ther terminals
CHAMPwhteEK
Honda Motorcycles
Mar 12, 2008 09:30 PM
1baddcivicsi
26
Oct 13, 2006 04:17 PM
sCeRaXn
Sep 26, 2004 09:42 AM
