Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Is the K20A-R (JDM) a direct bolton witha Civic EX 2001
Old Sep 5, 2006 | 11:33 PM
FRANK09's Avatar
Default Is the K20A-R (JDM) a direct bolton witha Civic EX 2001
I am planning on buying a Honda Civic EX 2001 and am planning on swapping a K20A-R (JDM) engine into the car I was wondering if this engine is a direct bolton or if it will fit on its stock mounts?
Old Sep 5, 2006 | 11:47 PM
toyomatt84's Avatar
Sanji
This has been covered numerous times before. So, you should be prepared to get flamed.
First off, <FONT COLOR="red"><u>Search</u></FONT>ing would save you time and effort. A simple search could have easily yielded your desired answer.
Secondly, no, you'll need plenty of parts to put a K-series (regardless of type) into your EM2. And, the mounts will definitely need to be custom. There is a huge following for this, so it's not that you're out of luck.
Check here for a nice rundown of what to do: http://www.xproductionz.com/k20swap/k20swap.html
Hasport makes the custom mounts you're looking for and you'll need a Kpro ECU just to get the engine running. Depending on if you'd swap out your 4bolt hubs for the DC5 (RSX) 5bolts, or the DC5 Brembo'd 5bolts, would be the decider for what axles you'd need. If you're sticking with the 4bolt, you'd go with EP3 (Civic Si, the hatchback) axles, and if you're going with the 5bolt, you'd need the DC5 axles. There's PLENTY more I didn't cover, but like I stated earlier, this has been covered before, and you're better off searching for results instead of taking the easy way out.
Old Sep 6, 2006 | 05:47 PM
bgoetz's Avatar
Default Re: Is the K20A-R (JDM) a direct bolton witha Civic EX 2001 (FRANK09)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FRANK09 &raquo;</TD></TR><TR><TD CLASS="quote">I am planning on buying a Honda Civic EX 2001 and am planning on swapping a K20A-R (JDM) engine into the car I was wondering if this engine is a direct bolton or if it will fit on its stock mounts?
Well I, myself will cut you a bit of slack this time and this time only, from now on SEARCH (I hope that others are as considerate and remember when they where a noob.)
first it is not a K20A-R it is a K20A that comes from a Integra type R. This motor is very similar to the K20a2 that comes from the RSX type S.
Second your question does not make sense "a direct bolt on or does it fit in stock mounts". Well even if there was such a thing as a direct bolt on engine swap it would have to fit into stock mounts to be considered a "direct bolt on".
Ok, so no it is far from a direct "bolt on" it requires alot of work and $, but when done it is well worth the work. If I were you and planned on swapping from the get go I would look into just getting a shell (no engine). Unless you really like the 7thgen body style I would maybe even consider looking at somthing like a CRX or an EK hatch, I really think that done right these look great and are WAY lighter than a 7thgen. I would buy the shell and then swap in the engine. Realistically you could get a EK hatch shell in good condition for 1-2K, you could then do the swap and do it right for 8-10K, throw on suspension, rims, and tires for 2K and you would have a 11-12 second sleeper for 11-14K. Just to put it into perspective with what you are thinking of doing (2001 7thgen and swap) you will end up spending 15-20K and will have a mid-high 13 sec sleeper. Either way is good, I have a 7thgen swap and LOVE it, but I did not plan on doing it when I bought the car, if so I would have done it a bit different.
If you want to do the 7thgen swap the thread that Toyomatt posted is a great resource. Some things in it are not 100% complete, but a mechanically inclined individual can figure it out. Xproductionz LOL
Check out K20a.org for more info on Kswaps. And remember SEARCH before you post. Oh, yeah welcome to the fourm
Modified by bgoetz at 2:57 AM 9/7/2006
Old Sep 7, 2006 | 08:08 PM
wbshrk16's Avatar
Definatly will need hasport mounts, plus some other parts. Here's a link to some guys DIY k20 install. He pretty much ripped it from hasport and added the prices that he spent for all the parts http://www.xproductionz.com/k20swap/k20swap.html
Old Sep 7, 2006 | 08:25 PM
toyomatt84's Avatar
Sanji
Default Re: Is the K20A-R (wbshrk16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wbshrk16 &raquo;</TD></TR><TR><TD CLASS="quote">Definatly will need hasport mounts, plus some other parts. Here's a link to some guys DIY k20 install. He pretty much ripped it from hasport and added the prices that he spent for all the parts http://www.xproductionz.com/k20swap/k20swap.html</TD></TR></TABLE>
Look two posts up. You could've just read my post.
Old Sep 9, 2006 | 01:41 PM
bgoetz's Avatar
Default Re: Is the K20A-R (toyomatt84)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toyomatt84 &raquo;</TD></TR><TR><TD CLASS="quote">
Look two posts up. You could've just read my post.</TD></TR></TABLE>
Man it has been a long time since I have participated on this forum, but look at Tyomatt go!!! He thinks he is big dick daddy
Old Sep 9, 2006 | 08:53 PM
toyomatt84's Avatar
Sanji
Default Re: Is the K20A-R (bgoetz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bgoetz &raquo;</TD></TR><TR><TD CLASS="quote">Man it has been a long time since I have participated on this forum, but look at Tyomatt go!!! He thinks he is big dick daddy </TD></TR></TABLE>
No comment.
Old Sep 9, 2006 | 08:56 PM
Vantage's Avatar
thats a little weird.
Old Sep 12, 2006 | 07:31 AM
Tiauna's Avatar
hondatech members favorite word = flamed lol
Old Sep 12, 2006 | 07:39 AM
fventura03's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18a_CRX &raquo;</TD></TR><TR><TD CLASS="quote">thats a little weird.</TD></TR></TABLE>
ownt
civiclov5u
Mar 12, 2011 10:11 PM
-BigD_
13
Jun 14, 2007 08:19 PM
SupraRXZ
Nov 9, 2006 06:16 PM
Dice21
Oct 12, 2005 10:24 PM
JDMC5
Apr 7, 2003 09:30 AM
