d15 cylinder head very hard to turn, timing always off
Old Sep 5, 2006 | 11:11 PM
217sportcompacts's Avatar
Default d15 cylinder head very hard to turn, timing always off
hey guys i am trying to adjust the engine time on my crx, i do everything correctly check everything then try to start it, it wont, then check it and it is thrown off again. i am thinking it may be the tensioner, but i am not sure, also when the timing belt is off of the cam sprocket and i try to turn the cam by myself with a ratchet it turns some then gets stuck and i cant turn it anymore it feels like the freaking ratchet is going to break! any suggestions thoughts? thanks
Old Sep 6, 2006 | 03:08 AM
Contender25
Guest
Posts: n/a
Take the spark plugs out, less force when turning it. I would change the tensioner, over look for anything out of the ordinary like a bent cam gear, and double check timing before start up, be careful it tends to slip when you get the belt on.
Bryant_novtec
Jan 13, 2014 01:09 PM
silent702
17
Feb 1, 2010 11:32 PM
Craigp23usa
Jan 23, 2007 09:13 AM
MachAF
Sep 10, 2005 04:02 PM
BB6racer
Jun 16, 2005 12:04 PM
