ecu pinout
ok im putting in a p0a ecu for now till I get my po6 back just sent it out for chipping to wire up vtec I no the pins to swap and I no that I gotta swap the o2 and egr but I dont no if I swap the pins with the plug facing me or away with the wires facing me and I have searched for a week but cant find a complete ecu pinout a4 and d6 is what I wire in for vtec is it the same as the po6 with vtec pinout
you look at the plug on the side the wires are going into (ie. imagine the ecu is still plugged in...)
its really simple, just look at where a4 (vtec spool) should be, it will a grn/yel, that will tell you if your looking at it right...2 over from the left on the bottom..
and yes, all the vtec pinouts are the same between civic/accord ecu
CivicxTree754
Apr 27, 2011 11:51 AM
