GE Sleeved H22 block part-out! endyn, manley, H22 built head! Ferrea, Venom, AEBS
Old Sep 5, 2006 | 08:25 PM
ChrisRicketts's Avatar
Default GE Sleeved H22 block part-out! endyn, manley, H22 built head! Ferrea, Venom, AEBS
<FONT COLOR="green">Well, i've decided to get rid of my setup seeing as that i was never able to get it going like i wanted, and i now need the money to finish off my college career.
Block------87mm sleeves- First off, I recently sent the block to Golden Eagle and had the HD sleeves put in (open deck btw), as well as a bore/hone job.....$1100 bucks alone. The block has been ran for about 250 miles, and unfortunately the crank was walking on me, causing internal failures of course. the old crank did scar the block a little, and took some meat off of where the thrust washer sits (about half), but the thrust washer will still have plenty to hang onto....nothing to really worry about. The cylinders could also use another hone job (not a big deal). I did buy another crank which i mic'd, and it's in great shape, and balanced. I can sell the block with or without the crank. The block will come with oil pickup, windage tray, balancer shafts, main caps, girdle, and oil pan. - girdle is a little dinged up from one of the thrust washers banging around temporarily, but works fine. Block was checked and everything is good to go!!
Block- $900 no crank, $1000 with crank. shipping will be around 50 bucks more.
Pistons- Endyn Rollerwaves 9.0~9.5:1 cr. These pistons are a little scarred on the fronts and backs- but some scotchbrite should be able to clean it up good. , rings are fine except on one piston- i broke one ring upon disassembly. a set for one piston can be bought from endyn pretty cheap. These are 87mm pistons........i paid 640 shipped. they are the best H22 pistons money can buy. They will come with wrist pins and rings. i want 360 bucks for these shipped.
Rods- Manley I-Beam rods. these things are monsters. nothing wrong whatsoever. i paid over 700 for these new. they are barely used. i'd like $495 shipped for these babies.
AEBS Head studs- torqued once, they've got some assembly lube on them, so they look a little dirty, but new condition! --- 115 shipped
AEBS Main studs- torqued once- these are still connected to the block right now --- 115 shipped
HEAD IS SOLD!!
Venom intake mani. SOLD!
GE fuel rail. SOLD!
Aeromotive A1000 Fuel pump. this thing is huge. good for more power than you're gonna have. used for 250 miles. paid 360 for it and the aeromotive filter.--- $300 for pump and filter combo.
SFP T3 Turbo manifold. this has been used for about 15,000 miles. it did have a crack but was repaired and works great. it has a 38mm w/g flange.--- $295
I'm also selling the intercooler piping in these pics. i painted it black. it's custom routed for a venom intake mani (which sits much lower than stock), i've got around $300 in it and the hoses/clamps. --- make offer
i have a full a-pillar triple gauge pod for the 97-01 prelude custom made from fiberglass. this thing cost me 120 bucks plus shipping, which is somewhat expensive for an item so light, since it is big and fragile. it COMPLETELY replaces the stock piece. it is primer black right now. it's for 52mm or 2-1/16" gauges.--- 110 shipped.
the center piece replacing the stock a/c vents and clock was custom fiberglassed for me and then painted black with a clear coat. it has spaces for 3 52mm gauges as well. if someone buys this piece it will need to be replaced with the stock piece in good shape and black.---- 100 bucks shipped plus your replacement.
3" exhaust - SOLD!
the crane cams plug wires, --- 40 shipped
distributor with new cap and rotor, --- SOLD!
and coil are for sale as well. --- 30 bucks
used h22 oil pump, --- 60 shipped
water pump, --- 25 bucks
timing belt, --- 50 bucks
main seal housing and main seal (new seal)-- not sure what its worth....$50 shipped?
stock transmission- m2y4, has difficulty shifting to 3rd at high rpms, but shifts pretty smoothly for most driving conditions.-- 400 plus shipping.
action stage 4 clutch disc and Heavy duty pressure plate (very used, needs new disc- but works),-- $40
Fidanza flywheel needs new surface plate (about 60 bucks on ebay for new plate), $65 bucks shipped.
</FONT>
Modified by ChrisRicketts at 2:56 PM 10/4/2006
Old Sep 6, 2006 | 06:28 AM
Default Re: GE Sleeved H22 block part-out! endyn, manley, H22 built head! Ferrea, Venom, AEBS (ChrisRicketts
Old Sep 6, 2006 | 06:07 PM
Old Sep 7, 2006 | 06:45 AM
abcdefghijklmnopqrstuvwxy&z
Old Sep 7, 2006 | 03:43 PM
Old Sep 7, 2006 | 05:35 PM
Old Sep 7, 2006 | 06:36 PM
Old Sep 8, 2006 | 06:31 AM
bump
Old Sep 8, 2006 | 08:36 AM
bump...
Old Sep 8, 2006 | 09:09 AM
Old Sep 8, 2006 | 11:25 AM
Old Sep 10, 2006 | 06:54 PM
bump
Old Sep 11, 2006 | 06:08 AM
Old Sep 11, 2006 | 10:00 AM
Old Sep 12, 2006 | 04:49 AM
bump
Old Sep 13, 2006 | 07:48 AM
up
Old Sep 14, 2006 | 06:43 AM
up
Old Sep 15, 2006 | 07:01 AM
up
Old Sep 16, 2006 | 07:09 AM
bump!
Old Sep 17, 2006 | 05:50 AM
Old Sep 18, 2006 | 05:56 AM
Old Sep 19, 2006 | 11:51 AM
Old Sep 19, 2006 | 05:00 PM
up
Old Sep 20, 2006 | 09:25 AM
Old Sep 20, 2006 | 02:37 PM
