JDM ITR SWAP in a 98 GSR
Old Sep 5, 2006 | 08:22 PM
JDM_DB8's Avatar
Default JDM ITR SWAP in a 98 GSR
I already tried searching... does anybody have any links on to do this swap and what i need.. i got the motor in and everything but when i start it up it dies unless i give it gas and its sputterin.. any help will be appreciated
Old Sep 5, 2006 | 09:13 PM
MJobe's Avatar
Default Re: JDM ITR SWAP in a 98 GSR (JDM_DB8)
Old Sep 5, 2006 | 09:19 PM
CleanLikeJdm's Avatar
Hype-R Stalker
Is it still the stock gsr ecu?
And if it just idles out, would adjusting the TB screw, or throttle cable help?
Old Sep 5, 2006 | 09:22 PM
DBAl's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_DB8 &raquo;</TD></TR><TR><TD CLASS="quote">I already tried searching... does anybody have any links on to do this swap and what i need.. i got the motor in and everything but when i start it up it dies unless i give it gas and its sputterin.. any help will be appreciated</TD></TR></TABLE>
I'm confused.... did you already do the swap and you aren't sure if you did it with the right stuff because it doesnt stay on?
Old Sep 6, 2006 | 06:40 AM
JDM_DB8's Avatar
Default Re: JDM ITR SWAP in a 98 GSR (DBAl)
I already did the swap, all sensors plugged in, i plugged off the vacuum nipples on the back of the intake manifold and the one on the tb, i have 2 ecu's to play with- jdm itr and a chipped p28. Seems like the car is not getting enough fuel at fireup and when I do fire it up i gotta give it gas or it dies, also misfiring. Just wanted to know if i had to modify any wires/pins, and anything obvious when doing a ITR swap in a GSR
Old Sep 6, 2006 | 06:44 AM
s2kdre's Avatar
u cant use the p28 unless u get a vtec pressure switch, jdm itr doesnt have one.
Old Sep 6, 2006 | 10:55 AM
JDM_DB8's Avatar
Default Re: JDM ITR SWAP in a 98 GSR (jdmhonda)
i swapped that over from the gsr motor
Old Sep 6, 2006 | 11:57 AM
lostshootingstar's Avatar
all the wiring is pretty straight forward. you dont have to modify anything.
are you getting check engine lights? hows your timing? did you replace the t-belt or anything?
it could be a lot of different things
Old Sep 6, 2006 | 10:37 PM
JDM_DB8's Avatar
Default Re: JDM ITR SWAP in a 98 GSR (lostshootingstar)
No CEL with both ecus. Car is just sputtering and wont idle. Maybe i messed up somewhere, hooked something up that i didnt have to, or missing something.. thats why i wanted to know if anyone got links to do the swap
Old Sep 6, 2006 | 10:38 PM
JDM_DB8's Avatar
No CEL with both ecus. Car is just sputtering and wont idle. Maybe i messed up somewhere, hooked something up that i didnt have to, or missing something.. thats why i wanted to know if anyone got links to do the swap, so i can backtrack what i did.. thanks
Old Sep 6, 2006 | 11:08 PM
SoTexDC2's Avatar
You just plugged the lines from the GSR Intake Manifold? or did you plug the ITR Manifold? The only thing you should have to plug is the Vaccum lines from the IAB setup. If your not getting a CEL, I would start with Vaccum. Did you change the timing belt before installing it?
Old Sep 7, 2006 | 06:47 AM
jdm_bones's Avatar
What TB are you running?
Old Sep 7, 2006 | 07:06 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_DB8 &raquo;</TD></TR><TR><TD CLASS="quote">No CEL with both ecus. Car is just sputtering and wont idle. Maybe i messed up somewhere, hooked something up that i didnt have to, or missing something.. thats why i wanted to know if anyone got links to do the swap</TD></TR></TABLE>
there are no links for this swap..trust me, i searched. getting info about it is like pulling teeth. There is really nothing different about it than swapping in any other motor in any other car. the wiring is all the same (except for the IAB).
i would check your timing. mabye its 180 off or something stupid.
Old Sep 7, 2006 | 07:21 AM
tensixty's Avatar
Celebrating 35yrs of Barbie
Have you checked to make sure you don't have a bad distributor? I had a nearly identical problem on a ls swap into an eg, turns out it was a bad distributor, got a new one and voila! it cranked right up and idled like it just came from factory.
Old Sep 8, 2006 | 11:06 AM
JDM_DB8's Avatar
Default Re: JDM ITR SWAP in a 98 GSR (tensixty)
i plugged the vacuum nipple on the back of the itr manifold.... and the one on the top of the tb ( where the canister usually feeds off on like on a usdm ls motor
Old Sep 8, 2006 | 11:07 AM
JDM_DB8's Avatar
im pretty sure my problem is either with vacuum, or timing is off or something.. havent had the time to look at it yet.. thanks for the help guys
Old Sep 8, 2006 | 11:28 AM
dohcMONSTER's Avatar
your timing is off. i had the same problem on my motor when my cam gears slipped
Old Sep 9, 2006 | 04:30 AM
SoTexDC2's Avatar
Are you sure your getting vaccum at your FPR ? If you can verify this, then I would say your source is good. Did you check your ignition timing? Also I would stick with the JDM ITR ecu for now, the p28 won't work unless its chipped for that motor.
wunfstgsr
Mar 2, 2009 07:20 PM
94lvstreetscene
Nov 20, 2006 07:31 PM
dzminiz
Nov 17, 2004 07:34 AM
sohc it to me
Oct 12, 2003 06:17 PM
