password fog lights for ek HELP!!!!
well i got the EK password fog lights and everything is hooked up but i keep blowing my insturment fuse? and the fogs will not work, just replaced the relay, maybe its not grounded right or something. any help wold be awsome. and i searched
Which fuse is blowing? The one supplied with the kit? Or the fuse for the guage cluster?..make sure where the plugs are going from the harness to the plugs going to the lights are matched up right, i had a problem with that where the wires were reversed in the plug so ground was going to power and blowing that fuse(make sure black is going to black and blue is going to blue on both sides).
Well, you should have an inline fuse ... so it's wierd that you're not blowing that. Check all your grounds, and check your inline fuse.
Also, make sure your accessory plugs are in the right spots.
hasn't blown the inline fuse just the one in the fuse box, checked the wires at the light and there is only one way it can go in. the light is on at the fog light switch, where is a good ground for both of them? there is on in the engine bay and one in the car.
I bolted my in-dash ground to the metal knee bolster, and I bolted my engine bay ground to my radiator support. Do you have a 99-00 or a 96-98? LMK, and I'll try to help you make sure all your wires are in place.
[Ennis_D]
Feb 8, 2013 06:40 PM
stupidasso15
16
Mar 15, 2012 09:07 PM
EJ8CIVIC
18
Feb 8, 2008 04:18 AM
