What rod for tig for mild steel
Old Sep 5, 2006 | 07:24 PM
JDMCRX's Avatar
Default What rod for tig for mild steel
What rod do u guys use for tigging mild steel???
Old Sep 5, 2006 | 08:04 PM
94h22's Avatar
Default Re: What rod for tig for mild steel (JDMCRX)
70s2 for mild
Old Sep 6, 2006 | 01:30 PM
franktype-r's Avatar
i use 308l on all steel , whether it be stainless or mild.
Old Sep 6, 2006 | 01:37 PM
KFMRC's Avatar
70s-2 its the only rod you need to keep good for mild steel and 4130 If you only keep this you will never worry about mixing things up.
Old Sep 6, 2006 | 03:43 PM
blueoval557's Avatar
Default Re: What rod for tig for mild steel (KFMRC)
Stick with the 70-S2. Not a good idea to use stainless filler on mild, as it will not flex at all, where the 70S2 will...which is why it is made for mild . There are times when stainless will work better, but majority of the time, 70S2 is the choice.
Kyle
TIGboy
Welding / Fabrication
21
Dec 3, 2011 04:45 PM
hoochhenry
Dec 1, 2011 04:32 AM
9295EJ-t
10
May 10, 2010 06:39 AM
.john.
Sep 4, 2007 06:39 AM
dfoxengr
Dec 16, 2006 08:30 AM
