triumph 600tt tips over...now it wont start???
Old Sep 5, 2006 | 07:06 PM
VRD^don's Avatar
Default triumph 600tt tips over...now it wont start???
okay..brother took his bike out for a ride...goes to park it..backs up to park...he accidently tips the bike over..brakes the foot rest, oil on the ground..trys to start it..it wont start...motor trys to crank but doesnt...not even one revolution..so we took the panels off and see a broke sensor..dont know what sensor it is..ill get pics tomorrow..oil seems to be coming from one of the tubes on the left side....no cracks in the motor or anything,...need help asap..thanks..
Old Sep 5, 2006 | 07:11 PM
len's Avatar
len
Default Re: triumph 600tt tips over...now it wont start??? (k_motor)
Sounds like the sensor that detects the bike's lean angle. It automatically cuts the bike off when you drop it to prevent further damage.
Old Sep 5, 2006 | 07:20 PM
marmaladedad's Avatar
That sensor usually resets when you turn the ignition off and back on.
Where is the crack that the oil came out of?
Old Sep 5, 2006 | 07:22 PM
len's Avatar
len
Default Re: (marmaladeboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marmaladeboy &raquo;</TD></TR><TR><TD CLASS="quote">That sensor usually resets when you turn the ignition off and back on.
Where is the crack that the oil came out of?</TD></TR></TABLE>
But he said the sensor broke. So it may be going crazy. I dunno. That's weird. Cracked case too with oil leaking out? Why even try to crank it at this point? Even if it does crank you'll get oil everywhere.
Old Sep 5, 2006 | 07:37 PM
Ahhh...broken sensor. Missed that part.
Good idea not to crank anything until you have a chance to go through the bike.
Old Sep 5, 2006 | 07:52 PM
VRD^don's Avatar
Default Re: (len)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by len &raquo;</TD></TR><TR><TD CLASS="quote">
But he said the sensor broke. So it may be going crazy. I dunno. That's weird. Cracked case too with oil leaking out? Why even try to crank it at this point? Even if it does crank you'll get oil everywhere. </TD></TR></TABLE>
well checked for cracks..looked and looked everywhere..and no cracks..oil seems to be coming out of one of the 4 tubes that runs on the left side of the bike...
Old Sep 6, 2006 | 01:10 AM
ngng's Avatar
spark plugs could be fouled
Old Sep 6, 2006 | 05:33 PM
VRD^don's Avatar
Default Re: (ngng)
bike wont even crank one revolution..sooo..i decided just to take it to the shop...see what happens....
Old Sep 7, 2006 | 10:42 AM
Bud's Avatar
Bud
New User
Default Re: (k_motor)
One of those tubes vents the air box. Its common for some oil to enter the airbox on the tt600 when tipped over.
Where is the broken sensor? Is it the kickstand sensor and the bike thinks it is down?
Old Sep 7, 2006 | 09:02 PM
VRD^don's Avatar
Default Re: (Bud)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bud &raquo;</TD></TR><TR><TD CLASS="quote">One of those tubes vents the air box. Its common for some oil to enter the airbox on the tt600 when tipped over.
Where is the broken sensor? Is it the kickstand sensor and the bike thinks it is down?</TD></TR></TABLE>
nope...its on the other side..theres like a tube that runs up the motor...the sensor is connected to it on the bottom..
Old Sep 7, 2006 | 11:04 PM
Bud's Avatar
Bud
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k_motor &raquo;</TD></TR><TR><TD CLASS="quote">nope...its on the other side..theres like a tube that runs up the motor...the sensor is connected to it on the bottom..</TD></TR></TABLE>
Now I'm confused, I thought you said the left side.
If its on the opposite side of the vent tubes, the only thing that I can think of is the cylinder head feed pipe which does have the low oil pressure warning light switch at the bottom of it. That tube runs up the front right of the engine though.
Maybe I'm not visualizing correctly.
Old Sep 10, 2006 | 07:23 PM
VRD^don's Avatar
Default Re: (Bud)
Maybe I'm not visualizing correctly. </TD></TR></TABLE>
no your correct..my fualt..wasnt thinking when i typed..yes your correct..but how can oil spill out like mad..made its own little puddle of oil...well the bikes at the shop...wont be till sometime this week till we here from them what is actually wrong with the bike.....
mike01f4i
Honda Motorcycles
17
May 8, 2009 11:17 AM
earnless3
Honda Motorcycles
Oct 9, 2008 02:35 PM
boosted420a
Honda Motorcycles
43
Aug 2, 2006 11:04 AM
plex
Honda Motorcycles
10
Apr 24, 2006 05:42 PM
p nut
Honda Motorcycles
May 24, 2003 11:48 PM
