What cams and header for 1.8l lsvtec setup
Old Sep 5, 2006 | 06:50 PM
import810's Avatar
Default What cams and header for 1.8l lsvtec setup
The Setup:
ls vtec
b18b1 block 81mm w/ acl berings + arp headstuds
Ctr 81mm pistons on shotpeened ls rods with arp rod bolts
knife edged crank
b16 head p&p w/ whatever valvetrain goes with cams
ls/vtec conversion kit
gsr water+oil pump
BLOX im with 68mm TB
310cc injectors
chipped p28 crome pro
havnt decided on header yet
what do you guys think? Im guessing c/r to be 12.7? with oem headgasket. What header and cams should I go with if ym goals are 200hp with good mid-upper range.
Old Sep 5, 2006 | 07:10 PM
ViF CrX's Avatar
Default Re: What cams and header for 1.8l lsvtec setup (import810)
what part of the bay you from?
Old Sep 5, 2006 | 07:33 PM
GSRCRXsi's Avatar
Default Re: What cams and header for 1.8l lsvtec setup (ViF CrX)
SMSP
Old Sep 5, 2006 | 08:28 PM
import810's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ViF CrX &raquo;</TD></TR><TR><TD CLASS="quote">what part of the bay you from?</TD></TR></TABLE>
Fremont/Pleasanton
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRCRXsi &raquo;</TD></TR><TR><TD CLASS="quote">SMSP </TD></TR></TABLE>
Also my budget is around 900 for cams + valvesprings and 600 for header
Old Sep 5, 2006 | 08:30 PM
WalkerGSR1's Avatar
Rage headers are awesome. rageimports.com
Old Sep 5, 2006 | 08:55 PM
b16-bomber's Avatar
Default Re: (WalkerGSR1)
if your buget was backwards you would have an awsome header and skunk2 cams... 900 bones for the smsp and ther rest for cams you would have a nce setup.... i cheaped out on a header.... bout the weapon-r race header.... it didnt fit for ****... it put me in a jam and i needed a header quick and i was out of money... i bought the rage header.... if i did it again i would have bought the smsp first.... though i am not dissapointed with my rage... i would have been happier with smsp... bottom line dont cheap out ... header makes or breaks MOST all motor setups
Old Sep 5, 2006 | 09:59 PM
import810's Avatar
Default Re: (b16-bomber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16-bomber &raquo;</TD></TR><TR><TD CLASS="quote">if your buget was backwards you would have an awsome header and skunk2 cams... 900 bones for the smsp and ther rest for cams you would have a nce setup.... i cheaped out on a header.... bout the weapon-r race header.... it didnt fit for ****... it put me in a jam and i needed a header quick and i was out of money... i bought the rage header.... if i did it again i would have bought the smsp first.... though i am not dissapointed with my rage... i would have been happier with smsp... bottom line dont cheap out ... header makes or breaks MOST all motor setups </TD></TR></TABLE>
where can you get cams, valvesprings, retainers, and cam gears for $600??? Please tell me if you find a place because I will buy it.
Old Sep 5, 2006 | 10:20 PM
UncleD's Avatar
Default Re: (import810)
Pm'd
Old Sep 5, 2006 | 10:31 PM
import810's Avatar
Default Re: (clean rice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean rice &raquo;</TD></TR><TR><TD CLASS="quote">Pm'd </TD></TR></TABLE>
pmed back lol
Old Sep 18, 2006 | 10:09 PM
import810's Avatar
ok im switching out the ctr pistons for some itr pistons (anyone want to buy some ctr pistons they are pretty new?),
I bought blox valvetrain wiht blox HSL cams.
What header now?
Old Sep 19, 2006 | 05:44 AM
HYBRID FREAK's Avatar
Smsp and skunk2 Pro1 cams.
dc4teg95
Jun 29, 2007 12:43 PM
DShowers
Dec 1, 2006 07:21 PM
norcalbayboy
11
Aug 16, 2006 10:36 PM
crxsimike
Apr 5, 2006 11:34 AM
rough_draft
Mar 16, 2005 10:15 AM
