55mm offset with prelude Si wheels on a 94 accord???
Old Apr 28, 2002 | 06:21 PM
TypeSH's Avatar
Default 55mm offset with prelude Si wheels on a 94 accord???
I'm planning to pickup a set of prelude Si (7-spoke) wheels, but want to be certain everything will work w/o any problems. The wheels are 15"x6.5" w/ a 55mm offset. I have a 1994 honda accord w/ the EX wheels and 205/55/15 tires (which will be reused w/ the prelude wheels). I'm also lowered about an inch to inch and a half on eibach prokits...
So all in all, would everything work fine? Things to consider or things to be concerned about (such as alignment, rubbing, etc)?
oh yea, and will i need any new parts like studs or lug nuts?
[Modified by TypeSH, 3:37 AM 4/29/2002]
Old Apr 28, 2002 | 06:53 PM
Kazmans94cord's Avatar
Default Re: 55mm offset with prelude Si wheels on a 94 accord??? (TypeSH)
im pretty sure you wont have any problems...but you might wanna get them balanced and get an alignment also just to make sure ya know? what are you gonna do with the EX wheel...if you gonna sell them i might be interested..lemme know man
Old Apr 28, 2002 | 07:14 PM
Accord94DX's Avatar
Quit biting my style yo....
I run 5mm spacers up front.
Old Apr 28, 2002 | 07:31 PM
Gennady's Avatar
New User
Just something for you to consider: During a recent oil change, I found out my 94 Prelude VTEC rims with 205-55's are rubbing on the springs and other parts. My suspension is stock. Therefore, I need spacers ASAP.
Old Apr 28, 2002 | 07:38 PM
TypeSH's Avatar
Default Re: 55mm offset with prelude Si wheels on a 94 accord??? (Wont be beat)
if you guys have lowered your car, how low are you guys?
So I would need 5mm spacers for sure? What about the rear?
[Modified by TypeSH, 4:38 AM 4/29/2002]
Old Apr 28, 2002 | 07:40 PM
Accord94DX's Avatar
i have em in the front only on mine. Mine dont have any problems in back. 195/55/15s.
Old Apr 28, 2002 | 07:51 PM
H23 Power's Avatar
you do know those wheels are 22 lbs a piece right? heavy *** rims
Old Apr 28, 2002 | 07:53 PM
Gennady's Avatar
New User
Default Re: 55mm offset with prelude Si wheels on a 94 accord??? (01GSR)
More like 18lbs. each.
Old Apr 28, 2002 | 08:00 PM
TypeSH's Avatar
hmm... do you think a 5mm spacer up front will be fine w/ 205/55/15 tires? It's kinda hard to get everything off the car and then sit and wonder what kind of spacer to use. Is there anyway Im supposed to check the clearance when I'm putting them on? Turn the wheel from lock to lock and see if it rubs???
even if they do weigh more than the accord wheels, they are 6.5" wide, better than the 5.5" wide accord wheels. My accord really isn't going anywhere fast (stock f22 motor), I might as well work on the other parts first.
Accord94DX's Avatar
the 92-93s are heavy. the 94-96s are light.
Old Apr 28, 2002 | 08:02 PM
Gennady's Avatar
New User
Mine rub while the wheels are straight.
Old Apr 28, 2002 | 08:23 PM
4doorH22's Avatar
Problem with a 5mm spacer (which is the thinnest you can get) is that you need longer wheel studs. Those are laborious to change.
Old Apr 29, 2002 | 12:12 PM
TypeSH's Avatar
Default Re: 55mm offset with prelude Si wheels on a 94 accord??? (4doorH22)
hmm... how much can I expect to pay for labor to studs/spacer done right?
Old Apr 29, 2002 | 12:16 PM
Accord94DX's Avatar
The fronts sound like a pain in the ***, the backs dont seem TOO horrible. I would figure $120 for the install in the front.
Old Apr 29, 2002 | 12:32 PM
TypeSH's Avatar
Default Re: 55mm offset with prelude Si wheels on a 94 accord??? (Accord94DX)
argh...
if i get a set of aftermarket wheels, such as rotas or koings, is it possible to get an offset that will bolt right up to the studs I have now? I'd like something easy to install, and where I won't have to worry about a spacer/incorrect offset.
Old Apr 29, 2002 | 12:34 PM
4doorH22's Avatar
Rears are pretty damn easy, 'cause it's easy to get the rear hub on and off easy.
If you're doing the front studs, might as well do your front rotors (if you need them) 'cause you gotta R&R the hub, which we all know is a PITA.
Old Apr 29, 2002 | 12:36 PM
4doorH22's Avatar
A +45 ET may work. I use a +38 ET (lower numbers mean higher offset) which gives plenty of room (but with 225s the rears rub the fender lip under full compression).
Old Apr 29, 2002 | 01:17 PM
H23 Power's Avatar
um, i had one in my apt for a while...it was 21.xx lbs closer to 22 lbs
the 94-96 rims are 16 lbs each
H23 Power's Avatar
yes, and the 7 spoke ones are 92-93
Old Apr 29, 2002 | 01:19 PM
Gennady's Avatar
New User
My 94 VTEC rims are about 16-18 pounds each.
Old Apr 29, 2002 | 01:27 PM
H23 Power's Avatar
which are the 9 spoke...not the 7 spoke pictured
Old Apr 29, 2002 | 01:30 PM
Gennady's Avatar
New User
Yes, I understand.
CmptchAV6's Avatar
mine are really heavy rims and they are only 5 spoke.
Old Apr 29, 2002 | 01:35 PM
H23 Power's Avatar
Default Re: 55mm offset with prelude Si wheels on a 94 accord??? (CmptchAV6)
i was just differentiating the heavy 92-93 and the light 94-96
the pictured ones are the heavy 92-93
the 94-96 have 9 slanted spokes
22 lbs is a lot of weight for a 15" rim
Old Apr 29, 2002 | 01:37 PM
CmptchAV6's Avatar
I wonder how heavy my rims without tires weigh. I bet it is something like 22lbs
