WHICH BUSHINGS TO BUY?
Old Sep 5, 2006 | 06:02 PM
e-honda's Avatar
Default WHICH BUSHINGS TO BUY?
Hey guys i've done my searching and read up on bushings. I am building up a 91 crx for road race only, and i want to know which bushings to get, as i have read that the master kits include unessecary bushings like for the shocks and what not. I know that all the lca's minus the rear upper are needed along with steering, what else?
Any help is greatly appreciated, thanks!
Old Sep 5, 2006 | 06:09 PM
e-honda's Avatar
Default Re: WHICH BUSHINGS TO BUY? (e-honda)
Scratch that i got my answer, and for future searchers i got it at
https://honda-tech.com/zerothread?id=997834&page=2
Well, since I have never purchased the kit as a whole, I'll use suspension.com's list of what the kit includes and someone can correct me if this is wrong:
Front & rear control arm bushings(rear: lowers only)
front strut rod bushings front & rear shock bushings
front end links
steering rack bushings
manual transmission shifter stabilizer bushings
ball joint and tie rod end boots
Old Sep 5, 2006 | 07:05 PM
theinfamouskonrad's Avatar
just don't use those ball joints/tie rod end boots... they suck.
Old Sep 5, 2006 | 07:26 PM
e-honda's Avatar
Default Re: WHICH BUSHINGS TO BUY? (theinfamouskonrad)
oh do they? whats wrong with them?
Old Sep 5, 2006 | 08:04 PM
eda6's Avatar
The tie rod/lower balljoint boots aren't too bad but the one for the upper control arm is horrible.
Basically the boots don't seal as well as oem.
Old Sep 8, 2006 | 12:17 PM
Tyson's Avatar
my advice is to replace your bushings with OEM only.
Old Sep 8, 2006 | 02:24 PM
way2much's Avatar
I'm in the same boat. I drove my car the other day(haven't driven it in two weeks cuz wife keeps taking it) and when I switch lanes on the freeway, the body just rolls and feels like it's floating every which way. I know my trailing arm bushings are bad but didn't know it would do that. Since I am down there I was thinking of changing everything that looks worn.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by theinfamouskonrad &raquo;</TD></TR><TR><TD CLASS="quote">just don't use those ball joints/tie rod end boots... they suck.</TD></TR></TABLE>
Is it because of what eda6 said? That they don't seal well?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EDA6 &raquo;</TD></TR><TR><TD CLASS="quote">The tie rod/lower balljoint boots aren't too bad but the one for the upper control arm is horrible. Basically the boots don't seal as well as oem.</TD></TR></TABLE>
Do you have any other reccommendations or tips on other bushings? I did a search also and no real help found.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">my advice is to replace your bushings with OEM only.</TD></TR></TABLE>
Is that with all of them or just certain ones? Also you wouldn't happen to have a diagram of the suspension and part #s off hand of the OEM pieces would you?
Thanks
I didn't mean to hijack but it is somewhat relavent
Thanks again
Old Sep 8, 2006 | 02:28 PM
Tyson's Avatar
Default Re: WHICH BUSHINGS TO BUY? (way2much)
balljoint boots are not bushings. and ive already said my peace about them in the link above.
look in the faq at the top of the forum for online dealers. they have picture catalogs and prices available.
skill178
Oct 30, 2011 08:08 PM
My_EFsedan
Oct 13, 2008 12:00 PM
Manolo
Suspension & Brakes
Jan 22, 2006 06:21 PM
