OBD0 Integra engine harness work for mpfi swap??
Old Sep 5, 2006 | 05:10 PM
D3U1LT's Avatar
Default OBD0 Integra engine harness work for mpfi swap??
want to use obd0 ls integra engine harness for b16a into crx si will this work? I ask because I cannot use the jdm harness correct?
Old Sep 5, 2006 | 07:44 PM
D3U1LT's Avatar
Default Re: OBD0 Integra engine harness work for mpfi swap?? (D3U1LT)
ah come on h-t
Old Sep 5, 2006 | 07:48 PM
crxnj's Avatar
since you have an si use the si harness,,and just add the 4 wire for vtec
you can probably make the jdm harness work somehow but everything is on the opposite side,,i would just take some plugs from it like 2nd o2,knocksensor,vtec solenoid,vtec pressure,ground,ecu pins,etc...
Old Sep 5, 2006 | 08:01 PM
D3U1LT's Avatar
Default Re: OBD0 Integra engine harness work for mpfi swap?? (Mr.speaker)
I forgot to mention i do not have a harness other than the jdm one. so will integra work?
Old Sep 5, 2006 | 08:05 PM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D3U1LT &raquo;</TD></TR><TR><TD CLASS="quote">I forgot to mention i do not have a harness other than the jdm one. so will integra work?</TD></TR></TABLE>
not plug and play. you can probably make it work though,get a wire diagram for the teg and crx and compare.
you cant find an si harness on ebay for cheap or anything?
Old Sep 5, 2006 | 08:32 PM
D3U1LT's Avatar
havent really looked i just found an integra harness for 25bux so....
Old Sep 5, 2006 | 09:04 PM
FIGARILA's Avatar
Modified by Heron of Alexandria at 9:46 PM 9/15/2006
Old Sep 15, 2006 | 07:39 PM
Ninja Mike's Avatar
Default Re: OBD0 Integra engine harness work for mpfi swap?? (Heron of Alexandria)
<FONT SIZE="4">Nobody help this ****** until he returns my $225 I sent him for an unforseen ITR oil pump!</FONT>
bad karma has caught up with you you little t00l.
Old Sep 15, 2006 | 08:22 PM
FIGARILA's Avatar
Default Re: OBD0 Integra engine harness work for mpfi swap?? (SleepEMike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SleepEMike &raquo;</TD></TR><TR><TD CLASS="quote"><FONT SIZE="4">Nobody help this ****** until he returns my $225 I sent him for an unforseen ITR oil pump!</FONT>
bad karma has caught up with you you little t00l.</TD></TR></TABLE> dude! you paid $225 for an "ITR" oil pump?
Old Sep 15, 2006 | 08:33 PM
Ninja Mike's Avatar
<FONT SIZE="5">He told me it had the TODA gear in it!!!</FONT> he is a lying sack of skewering s---!
Sosa0311
Sep 15, 2012 11:14 AM
seldon
Jul 3, 2009 09:22 PM
jarel
Nov 3, 2004 03:31 PM
85mm LS VTEC
Jul 6, 2004 10:20 AM
Driven
Mar 24, 2004 08:55 AM
