searched POWERsteering removal on 4th gen
Old Sep 5, 2006 | 04:57 PM
93ludesitec's Avatar
Default searched POWERsteering removal on 4th gen
hey i am in the process of removing my powersteering on my 93 lude si and i was following the faq write up but its for a 5th gen and mine has 4 lines coming out of it???? can someone help
Old Sep 5, 2006 | 05:01 PM
nonvteclude's Avatar
Default Re: searched POWERsteering removal on 4th gen (93ludesitec)
in the faq's in th general section there is a powersteering removal thread
Old Sep 5, 2006 | 05:03 PM
Default Re: searched POWERsteering removal on 4th gen (nonvteclude)
thats for 5th gen though... mines a 4th gen, totally diff
Old Sep 5, 2006 | 05:09 PM
look at yours and then look at the pictures everything is the same but that lil mount on the top
Old Sep 5, 2006 | 05:25 PM
soundbomber's Avatar
4lines = 1 inbound 1 outbound from pump, 1 inbound 1 outbound to vss. you can loop the vss lines
Old Sep 5, 2006 | 05:48 PM
Default Re: searched POWERsteering removal on 4th gen (soundbomber)
thank you thats what i needed to know!!!
Old Sep 5, 2006 | 06:06 PM
mattmw88's Avatar
Just an FYI I gained 7 WHP on the dyno by removing my ps belt... deffinetly worth it when at the drag strip or when I need all the power I can get
Old Sep 5, 2006 | 06:43 PM
98vtec's Avatar
moderator emeritus
Default Re: searched POWERsteering removal on 4th gen (mattmw88)
did you do back to back dyno runs on the same day?
Old Sep 7, 2006 | 10:30 AM
mattmw88's Avatar
Default Re: searched POWERsteering removal on 4th gen (98vtec)
I pulled the belt off while on the dyno in between runs.
Old Sep 7, 2006 | 11:51 AM
mgags7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattmw88 &raquo;</TD></TR><TR><TD CLASS="quote">I pulled the belt off while on the dyno in between runs.</TD></TR></TABLE>
thats the **** i like to see
THANKS for some great info
MIMIC_INC
Meets & Events
Jul 20, 2015 11:21 AM
us31wking
Jul 23, 2007 05:16 AM
PreludePhill
Feb 28, 2007 10:25 AM
Thuttle88
Sep 10, 2005 09:41 AM
