Dyno'd my almost stock B16 today. Check it out
Old Sep 5, 2006 | 04:42 PM
DC5ftmfw's Avatar
Default Dyno'd my almost stock B16 today. Check it out
Set up:
JDM B16A
Weapon R intake
AEBS intake manifold
ITR cams
DC 4-1 header (2" collector by the way)
custom crush bent 2.5" exhaust
Result: 160whp and 108tq
This was only revving to 8k on a completely untuned ECU. It was a stock 99-00 Si ECU. I'll post the graph in a little while if I can get it to work and you'll see that it's still pulling too. Im guessing with tuning and revving to about 8.5k...I'd maybe get around 170whp. My 1st pull I made 149whp and 106tq and that was with a chipped p28 running to rich in some places and to lean in others and only revving to 7600. I was also using a PasswordJDM intake as well. I put the stock ECU in there and made 155whp, then put a Weapon R intake in and made 160. I don't think that's to bad considering it's a 1.6L and it's completely untuned and being underrevved lol. Anyway, if you have any 2 cents, lemme know. Thanks gusy
Old Sep 5, 2006 | 05:32 PM
SkoundrelUSA's Avatar
cute little bastard
Default Re: Dyno'd my almost stock B16 today. Check it out (StevesEKhatch)
damn thats pretty impressive...
Old Sep 5, 2006 | 05:37 PM
DC5ftmfw's Avatar
Default Re: Dyno'd my almost stock B16 today. Check it out (SkoundrelUSA)
I thought it was pretty good. My best time so far was a 15.7 and that was with the password intake and the chipped p28 so I was only revving to 7600. Im gonna practice more this Friday and see if I can pull off a 15.3 or better. By the way, the motor's in a '97 EK hatch.
SomeDude56's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StevesEKhatch &raquo;</TD></TR><TR><TD CLASS="quote">Set up:
JDM B16A
Weapon R intake
ITR cams
Looks like you've got one of those factory freak motors (not being an asshat....seriously I've heard/seen some crazy differences in identical motors). But I would really look into doing your valve springs/ retainers b.c itr cams @ 8500 would make me a little nervous.
Old Sep 5, 2006 | 07:29 PM
DC5ftmfw's Avatar
Default Re: Dyno'd my almost stock B16 today. Check it out (SomeDude56)
Oh yea for sure. I'm not revving over 8k with the stock valvetrain. I'd be doing good to make 160whp at 8500 but I made it at 8k and it's still pulling hard. And like I said, there hasn't been any tuning done at all. Not even an adjustable FPR. Overall, Im very pleased with the results.
Old Sep 5, 2006 | 07:53 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StevesEKhatch &raquo;</TD></TR><TR><TD CLASS="quote">I thought it was pretty good. My best time so far was a 15.7 ....</TD></TR></TABLE>
Somebody needs some dragging lessons
Old Sep 5, 2006 | 08:20 PM
b16-bomber's Avatar
Default Re: Dyno'd my almost stock B16 today. Check it out (cb7-R)
yea practice at the drags.. work on lauching and 60 ft times... dont miss gears... my b16 with 158 whp was pullin 14.8's in a hx coupe.... dont be shy to bang gears drive the **** out of it at the track... but look into getting it tuned nice numbers
Old Sep 5, 2006 | 08:26 PM
biassj's Avatar
Default Re: Dyno'd my almost stock B16 today. Check it out (b16-bomber)
Nice numbers, what kinda dyno was it? Still good numbers though. Get some good tires and practice more. Those B16's like higher rpm launches.
Old Sep 5, 2006 | 08:41 PM
DC5ftmfw's Avatar
Default Re: Dyno'd my almost stock B16 today. Check it out (biassj)
thanks guys, and yea I need more practice at the track. Bad. I've recently just started going often. I've found that the best place to launch in my car is at about 2600 RPM. Anything higher than that and it wheel hops pretty bad. My 60fts are bad though. Im going to practice more this Fri. My shifts get better every time I go. Oh and it was on a DynoJet
Old Sep 5, 2006 | 08:50 PM
b16-bomber's Avatar
2600 is a lil low... mess around with it... wheel spin is oki as long as its not too bad... there is a fine grey area... dont get to crazy nothing about 5000 on street tires, but tracks are stickier than the street give that thing hell.... if it wheel hops try a lil higher launch to spin a bit more
Old Sep 5, 2006 | 08:59 PM
DC5ftmfw's Avatar
thanks for the tips bro, I'll deff try that this Friday
Old Sep 5, 2006 | 09:58 PM
Suck my DX's Avatar
nice numbers...but 2600 is way too low to launch a b16 at...at least 4500...try to feather the clutch on takeoff...it might seem a little intimidating at first,but try it out a few times before you hit the track...youll notice a nice difference at the track...powershift every gear
Old Sep 5, 2006 | 10:23 PM
salman's Avatar
very nice numbers,
Some pictures will be very nice,
Old Sep 5, 2006 | 10:25 PM
B18 CYA's Avatar
Default Re: Dyno'd my almost stock B16 today. Check it out (Suck my DX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suck my DX &raquo;</TD></TR><TR><TD CLASS="quote">nice numbers...but 2600 is way too low to launch a b16 at...at least 4500...try to feather the clutch on takeoff...it might seem a little intimidating at first,but try it out a few times before you hit the track...youll notice a nice difference at the track...powershift every gear</TD></TR></TABLE>\
yah on street tires i had to laugh pretty much off idle or i would spin through 3rd.. got some bfg drags and if i heated them up i was launching at 5500-6000 on the street and they hooked pretty good! (never got to run at the track with good tires )
you just gotta find a good combo or slipping the clutch/feathering the gas.. just takes practise.. good luck
oh btw it was a stock gsr crx.
Old Sep 5, 2006 | 10:27 PM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
Default Re: Dyno'd my almost stock B16 today. Check it out (salman)
good numbers for a b16
Old Sep 5, 2006 | 11:08 PM
vtecsi00's Avatar
Default Re: Dyno'd my almost stock B16 today. Check it out (WHITFIELD-TUNED)
looks good for not tuning can't wait to see what it does tuned
Old Sep 5, 2006 | 11:25 PM
salman's Avatar
That wapon R intake system is really some thing
Old Sep 6, 2006 | 12:35 AM
peacexisxfree's Avatar
Default Re: (salman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by salman &raquo;</TD></TR><TR><TD CLASS="quote">That wapon R intake system is really some thing</TD></TR></TABLE>
haha
op: nice numbers for what you're running.
Old Sep 6, 2006 | 01:31 AM
jessevtec's Avatar
nice numbers with the lil motor, if you can get that car down to at least 2300-400 with you in it and some 20 inch slicks launching at 7500 i bet youll see a high 13 run. what weapon r intake was it is it the new ones?
Old Sep 6, 2006 | 01:43 AM
salman's Avatar
Default Re: (jessevtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jessevtec &raquo;</TD></TR><TR><TD CLASS="quote">what weapon r intake was it is it the new ones?</TD></TR></TABLE>
, yeah its the new one,
Old Sep 6, 2006 | 03:02 AM
SomeDude56's Avatar
Ive got a feeling your not preloading your drive-train, are you?
Old Sep 6, 2006 | 07:50 AM
SaturdayNightWrist's Avatar
Appears to be duplicate account.
seems about right to me. i had a 2 layer hg, gsr cammed, gsr head b16 (pr3 pistons) make 150 so 10 hp for the intake mani and cams... yea i can buy that
Old Sep 6, 2006 | 07:57 AM
Project99EK's Avatar
JDM B16A
Weapon R intake
ITR cams
I dont thinka nyone payed attention to that crush bent POS, he would gain power just getting rid of that crush bents are horrible for power even on a somewhat stock motor.
Old Sep 6, 2006 | 08:19 AM
Default Re: Dyno'd my almost stock B16 today. Check it out (Project99EK)
although i agree, i dont think he would pick up but a couple 10ths at the track with a mandrel bent system and that motor. not arguing, i could be wrong....
Old Sep 6, 2006 | 04:22 PM
DC5ftmfw's Avatar
Default Re: Dyno'd my almost stock B16 today. Check it out (peacexisxfree)
thanks for all the replies guys. I'm going to get the graph up as soon as possible. Im still amazed with the results. It's nothing special but to have absolutely no tuning, a shitty crush bent exhaust, and underrevving it, it's pretty good I think. I can't wait to see what it makes revving to 8.5 and tuning. And yea, Im not doing to good at the track. But then again, my 15.7 was with 149whp and only revving to 7600...Im hoping for at least a 15.3 when I go back this Fri with the stock ECU and the Weapon R intake.
