2nd 02 senor for b16a
Old Apr 28, 2002 | 05:53 PM
ef civic's Avatar
Default 2nd 02 senor for b16a
i have a dc header with one 02 right before the cat my ? is can i run that one or do i have to weld another one to tha header if so any sugestions
Old Apr 28, 2002 | 05:57 PM
CRX7's Avatar
Default Re: 2nd 02 senor for b16a (ef civic)
You can't use the one down near the cat, the 02 sensor won't get hot enough to work correctly. You need to plug the lower one by the can and weld 2 in the stock location.
Old Apr 28, 2002 | 06:01 PM
ef civic's Avatar
were is the stock location
Old Apr 29, 2002 | 04:36 AM
B16ED4G's Avatar
I have a DC sports 4-2-1 that I had two O2 sensor bungs welded into for my B16A. If you look at the stock manifold you can get a good idea where they should be welded, two clearance issues to look out for, the A/C compressor and the front lower cross member. instead of having my sensors coming straight out and being too close to the rad fans, I had mine welded so that they point outward.
you can purchase the O2 sensor bungs from summit of jegs, then have a competent person drill and weld them onto the header mine was Heli-arch welded, its a cooler type of weld so it doesn't burn through the header, they are pretty cheaply made for how much they cost
Chris
Beyond Imagination
Jun 18, 2004 09:52 AM
CRXSIFUEL
Jul 7, 2002 07:01 PM
solkid
Apr 9, 2002 09:33 AM
BuddhaSiR
13
Oct 25, 2001 01:49 PM
