DOHC Conversion
Old Sep 5, 2006 | 03:36 PM
Japan's Avatar
Default DOHC Conversion
Searched it up, but i cant find anything :S
I have a DOHC ZC head sitting in my Garage, will this head bolt up to a D16A6?
Any special modifications required? I have heard its possible a couple times, then other times i hear it isnt...
Thanks!
Old Sep 5, 2006 | 03:53 PM
cbp_crx's Avatar
Default Re: DOHC Conversion (Japan)
no its not reallly possible, the head is too big for the block
Old Sep 5, 2006 | 04:32 PM
jhota's Avatar
it's possible. but isn't worth it. the water jacket doesn't line up exactly, the cam gears don't really work right with the A6, and the combustion chamber is so big compared to the A6 you end up with around 8.25:1 compression.
so basically, no it won't work. or rather it will, but nowhere near as well as a stock A6.
Old Sep 5, 2006 | 04:34 PM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: DOHC Conversion (jhota)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jhota &raquo;</TD></TR><TR><TD CLASS="quote">it's possible. but isn't worth it. the water jacket doesn't line up exactly, the cam gears don't really work right with the A6, and the combustion chamber is so big compared to the A6 you end up with around 8.25:1 compression.
so basically, no it won't work. or rather it will, but nowhere near as well as a stock A6.</TD></TR></TABLE>
Just try to find a ZC block, you should be able to find one for a good price.
EfSedanLove
Mar 22, 2010 02:32 AM
94hondacivicvtec
Jun 12, 2007 09:26 PM
CroCivic90
22
Dec 3, 2005 03:42 PM
NirVTEC
Oct 18, 2005 12:12 PM
TodaCivic
Jun 8, 2004 12:38 PM
