ITR Camshafts in an SiR-II B16a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackEK4coupe »</TD></TR><TR><TD CLASS="quote">Will I notice a difference?</TD></TR></TABLE>
it will be a noticeible improvement...but I'd try to upgrade to the ITR valve springs/retainers and get it tuned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.RHTuner »</TD></TR><TR><TD CLASS="quote">
it will be a noticeable improvement...but I'd try to upgrade to the ITR valve springs/retainers and get it tuned </TD></TR></TABLE>
does the stock valve train handle the ITR cams okay? or is this necessary?
yep, they'll do just fine.
had them for more than 4 months now. did 7 passes at a local track plus it's my DD. haven't touch my valve tappets since i gapped them 2 weeks after when i did this swap.
last time i checked my clearances was like almost 2 weeks ago when i replaced my vc gasket and plug oil seals. tappets are still in specs.
P28 CromePro tuned at stock rev limits
I know of people running the CTR/ITR cams on stock B16A valvetrain. Not recommended, but it's not going to fall apart like running Skunk2 Pro 1's on stock B16A valvetrain. Should consider upgrading the valvetrain if you can afford to do so though, just so that you can have your engine tuned to rev past 8200 to take advantage of the cam's design.
I'd run them
I'd run them
VWkila
Jun 21, 2003 04:08 AM
