97 civic jdm b18c with major problems need help
Old Sep 5, 2006 | 03:06 PM
b18c1vc97's Avatar
Default 97 civic jdm b18c with major problems need help
sunday night i was driving back to my house, and i turned on my road, and the car just cut off on me, so i pull over, it barely wants to start, and when it does it has a terrible miss fire...so i tow it home, and just let it sit, it was 130 in the morning, and havent had a chance to play with it till today, when i pulled the plugs out they were disgusting, so i replaced them, still same thing, replaced wires, same thing just replaced the cap and rotor... i was staring at it today after i noticed the plug wire wouldnt go down and seal to the valve cover and i looked down into cylinder #2 and in the spark plug hole, there is like this metal piece thats round and smooth on the inside, sticking out, with a hex pattern around it...and its sticking completely up therefore, plug wire has about a 1 inch gap away from the head where its supposed to seal...
any ideas fellas??
anyhelp is appreciated
-- Junior
Old Sep 5, 2006 | 03:57 PM
Formula's Avatar
Default Re: 97 civic jdm b18c with major problems need help (b18c1vc97)
I don't know about some of your other problems but I have seen the same thing happen to other cars before. You mentioned that you changed the distributor cap and rotor but did you replace the coil and ignitor?
I have replaced the coil and ignitor or other cars that shut off while they were running and it usually fixes the problem. Hopes this helps.
Old Sep 5, 2006 | 04:24 PM
fmrprojects's Avatar
Default Re: 97 civic jdm b18c with major problems need help (Formula94)
maybe something just fell down the spark plug hole. and it sounds like your ignitor went bad. a bad ignitor will cause a bad misfire
mavvrik
Apr 3, 2011 11:26 AM
radicaled434
Jun 10, 2008 03:51 PM
HTn00b
43
Nov 8, 2006 02:35 PM
swappedcx
Jan 14, 2006 09:04 AM
Yokohama
12
Jul 2, 2003 12:59 AM
