Buddy Club Spec III+ Powered B16
Old Sep 5, 2006 | 11:48 AM
ultimatehonda's Avatar
Default Buddy Club Spec III+ Powered B16
Finally able to hit up the dyno to do some tunning. The set up and graph:
2000 Civic Si
B16a2
Buddy Club Cam Gears
Omni Power Dual Valve Springs and Retainers
AEBS Intake Manifold
65mm Ported TB
Aem CAI
Greddy Header with Collector Mod
Resonated Test Pipe
Greddy EVO Exhaust
Tuned with Crome Free 1.2 by Me.
Was able to fix big dips in HP and TQ with tunning. In some areas Over 20whp was gained. Cam Gears set to 0, +2
Final Numbers 170whp 111TQ.
Old Sep 5, 2006 | 11:50 AM
KYSI's Avatar
Nil Desperandum
Default Re: Buddy Club Spec III+ Powered B16 (ultimatehonda)
Very nice
Old Sep 5, 2006 | 12:31 PM
97L-esVeeTeg's Avatar
very nice graph, torque is board flat...hell almost looks as if you could of reved it out a little more.
Old Sep 5, 2006 | 12:38 PM
strsi's Avatar
Default Re: Buddy Club Spec III+ Powered B16 (97L-esVeeTeg)
definatly looks good. nice setup
Old Sep 5, 2006 | 12:42 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97L-esVeeTeg &raquo;</TD></TR><TR><TD CLASS="quote">very nice graph, torque is board flat...hell almost looks as if you could of reved it out a little more. </TD></TR></TABLE>
Thanks, I tried reving all the way to 9k but then just didnt make any more hp. Im surprised it made power all the way to 8500. Everyone always says the buddy club spec III's only really make power to 8k.
Old Sep 5, 2006 | 02:54 PM
mar778c's Avatar
Community Builder
Community Influencer
nice tune.
BC3+ are no joke.
Old Sep 5, 2006 | 03:46 PM
JCushing's Avatar
Default Re: Buddy Club Spec III+ Powered B16 (mar778c)
nice, wish i had stock in BC, they seem to be selling alot of these cams
Old Sep 5, 2006 | 05:49 PM
Anti-Drama Queens's Avatar
ANOTHER nice dyno for bc 3+ cams.....good job, nice build
Old Sep 5, 2006 | 06:43 PM
UncleD's Avatar
Default Re: (mr_ducksauce)
Seems like we're seeing allot of dynos with the 3+ making power to 8,500.....boy was I under the wrong impression!
Old Sep 5, 2006 | 09:40 PM
Combustion Contraption's Avatar
Default Re: Buddy Club Spec III+ Powered B16 (JCushing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JCushing &raquo;</TD></TR><TR><TD CLASS="quote">nice, wish i had stock in BC, they seem to be selling alot of these cams</TD></TR></TABLE>
It has 1 too many lobes for you.
Old Sep 5, 2006 | 11:00 PM
salman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ultimatehonda &raquo;</TD></TR><TR><TD CLASS="quote">Finally able to hit up the dyno to do some tunning. The set up and graph:
2000 Civic Si
B16a2
65mm Ported TB
Aem CAI
Resonated Test Pipe
Greddy EVO Exhaust
your on stock compression, 10.2~4:1, ??
Old Sep 6, 2006 | 12:26 AM
firme ef8's Avatar
Default Re: Buddy Club Spec III+ Powered B16 (salman)
nice numbers. we have almost the exact mods. im hoping to put down that much.
Old Sep 6, 2006 | 01:47 AM
salman's Avatar
can i ask for t.b pictures
Old Sep 6, 2006 | 10:05 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by salman &raquo;</TD></TR><TR><TD CLASS="quote">
your on stock compression, 10.2~4:1, ??</TD></TR></TABLE>
Yes I am on stock compression....10.2.1
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by salman &raquo;</TD></TR><TR><TD CLASS="quote">can i ask for t.b pictures
Yes I have some but at home....I will post them up later tonight.
Old Sep 6, 2006 | 11:44 AM
BoBo Racing's Avatar
looks good how much timing did u add, and looks like ur running a lil lean towards the end
Old Sep 6, 2006 | 12:22 PM
Furyof4's Avatar
Default Re: Buddy Club Spec III+ Powered B16 (BoBo Racing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr_ducksauce &raquo;</TD></TR><TR><TD CLASS="quote">ANOTHER nice dyno for bc 3+ cams.....good job, nice build</TD></TR></TABLE>
Old Sep 6, 2006 | 04:52 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoBo Racing &raquo;</TD></TR><TR><TD CLASS="quote">looks good how much timing did u add, and looks like ur running a lil lean towards the end </TD></TR></TABLE>
Timming was added as needed. If you look at the end of the graph it says 13.38, Thats relativly stoichometric considering its a naturally aspirated engine.
Old Sep 6, 2006 | 05:09 PM
Default Re: (salman)
As requested for the TB pictures:
Props to Max bore on the board....Great job and service
Old Sep 6, 2006 | 05:10 PM
StreetEG's Avatar
nice numbers! you put down 10 more whp and 8 more wtq then I did on a similar setup. And i am thinkin it had a lot to do with cam gears. I cant wait till mine come in... how did you go about setting the cam timing?
Old Sep 6, 2006 | 05:16 PM
Default Re: Buddy Club Spec III+ Powered B16 (StreetEG)
What was your setup? I actually went by omni power's cam timming that he found to be the best for those cams on his motor when he had dynoed them a few years back. I set it and once I got to the dyno saw the numbers I was putting down so decided to leave it be. I don't think I could have extracted anymore power from this set up....
Old Sep 6, 2006 | 05:36 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ultimatehonda &raquo;</TD></TR><TR><TD CLASS="quote"> Thats relativly stoichometric considering its a naturally aspirated engine. </TD></TR></TABLE>
Stoich is stoich regardless if its naturally aspirated or forced induction. The only way stoich varies is if the fuel varies. I think what you wanted to say was thats where the motor made the best peak power. If you run stoich mixtures that high up, your in for some trouble.
Old Sep 6, 2006 | 06:10 PM
StreetEG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ultimatehonda &raquo;</TD></TR><TR><TD CLASS="quote">What was your setup? I actually went by omni power's cam timming that he found to be the best for those cams on his motor when he had dynoed them a few years back. I set it and once I got to the dyno saw the numbers I was putting down so decided to leave it be. I don't think I could have extracted anymore power from this set up....</TD></TR></TABLE>
hmm so intake 0 exhaust +2?
Old Sep 6, 2006 | 06:24 PM
mar778c's Avatar
Community Builder
Default Re: (clean rice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean rice &raquo;</TD></TR><TR><TD CLASS="quote">Seems like we're seeing allot of dynos with the 3+ making power to 8,500.....boy was I under the wrong impression!</TD></TR></TABLE>
Yeah, I'm seeing this also, but I would swear they must be BC4s. That no drop off in power seems alot like BC4 not BC3+s. Anyway nice numbers, again.
Old Sep 6, 2006 | 06:55 PM
Default Re: (mar778c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mar778c &raquo;</TD></TR><TR><TD CLASS="quote">
Yeah, I'm seeing this also, but I would swear they must be BC4s. That no drop off in power seems alot like BC4 not BC3+s. Anyway nice numbers, again.</TD></TR></TABLE>
Right after 8600 the power drops off. I dynoed to 9 in some runs to see where it made power till. The power is good through out the band, but I think BC4's would just be way to big for the compression I have.
Old Sep 6, 2006 | 07:10 PM
mtber's Avatar
Looks pretty good. What did you end up for cam timing ?
